View Poll Results: What is the RPM at idling?
8,000
0%
Voters: 24. You may not vote on this poll
What is your engine speed at idling?
I have experienced stalling last week, and on both occasions I was moving out from a gas station. I have also noticed that my car would go backwards when moving off from slopes. I think they are due to the low engine speed at idling.
Edit: Sorry, Lomag is right, the RPM should be in the hundreds instead
Guest
Posts: n/a
Mine used to be 550 rpm but dealer upped it to 750 rpm to prevent stalling and sliding back on slope.
Originally Posted by Lomag' date='Sep 26 2004, 09:13 PM
I think your numbers are off by a factor of ten. You mean 500, 600, 700, etc.. rpm right?
Mine idles at 750 rpm usually
[snapback]38397[/snapback]
Guest
Posts: n/a
I think it is due to car being too heavy after petrol top up coupled with low idling rpm. So, the engine had problem adjusting to the sudden change of weight.
Originally Posted by ///M-trois' date='Sep 26 2004, 11:21 PM
That's perculiar - all reports of a stalled engine was when we were pulling out of a petrol station (mine included!)?
Mine idles at 550ish
[snapback]38419[/snapback]
My Ride: 2004 545iA Titanium Silver/Gray, Poplar----Cold Weather Pkg, Comfort Seats, Logic 7 Audio, Heated Rear Seats
500 or 750 RPM. (545 Steptronic)
I'm not sure what variables are causing the two different idle speeds. The AC compressor has been discussed, but I am not certain this is the only variable.
I have occasional stumbles or hesitations starting from a stop, which I believe only occur when the engine is idling at 500 RPM.
