What is wrong with my headlight??!!
Old Jun 19, 2009 | 12:04 PM
ziad's Avatar
So my left headlight goes out a few days ago and the first thing that comes to my mind is, I just need a new light bulb.
I have a 2004 525i with xenon adaptive headlights.
I just stopped at the dealership to pick up a new bulb because trying to find a new bulb online was very confusing because there is two different types of bulbs (D1S, D2S) and I wasn't sure which one to get, so I thought I'll go to my local dealership, I'll pay a little more and get the right part... WRONG!!
The dealership just made more confused. Even though I gave them my VIN, they still didn't know what type of bulb I need, plus, they said it doesn't really have to be the bulb, it could also be the "igniter" or the module. They also gave me a list of prices and it doesn't look pretty...
I noticed that when I turn my headlights on, the bad headlight blinks for a split second. Also, both low and high beam are out.
Does anyone know it could possibly be?
Is there an easy way to troubleshoot?? Besides moving the good bulb from the other side to see if it would work?
Any help is greatly appreciate it.
Thanks.
Old Jun 19, 2009 | 07:39 PM
JECAR's Avatar
moving bulbs to the other side is the easiest and should be the first step in diagnosing a headlamp problem. first thing you need to know is if its the bulb thats gone bad or the igniter/ballast. And try not to buy things like bulbs from the dealer. if you have OEM bi-xenon headlamps you need D2S bulbs.
Old Jun 19, 2009 | 10:21 PM
John@Motorcepts's Avatar
Banned
My Ride: A Car
correct about the testing the bulb but incorrect about D2S.
Bixenons headlamps may also have D1S bulbs. BMW just LOVED to confuse people. My friend's car has D2S and I have D1S. It's awkward and it seems that they randomly put it there. Take a pic of ur bulb and I can help u out. But first, swap the bulb to see what it is. D1S includes the ignitor.
Old Jun 20, 2009 | 12:25 PM
SCardamon's Avatar
My Ride: 06 530i Premium and Cold Weather Package Orient Blue, Tan Interior
There is also another solution set. Drive during the day only and distract yourself with other things to keep your mind off it.
I didn't say it was a good solutios set, just one of them lol. Good luck man
Old Jun 20, 2009 | 12:31 PM
PraiseTheLowered's Avatar
yeah i have adaptive bi-xenon and have d1s bulbs
whats the damn difference between the two bulbs
Old Jun 20, 2009 | 02:47 PM
BlaSTiWi's Avatar
For your reading enjoyment ... http://faqlight.carpassion.info/hl-hid-bulbs.htm
Old Jun 20, 2009 | 02:58 PM
look into your headlight (while off) and around the bulb you should be able to see and read "BMW bi-xenon" or something like that, and it should read either D2S or D1S and you will know
Old Jun 30, 2009 | 08:34 AM
ziad's Avatar
It does actually say D2S.
Thanks NeRwEEzy
Old Jun 30, 2009 | 09:24 AM
or_550i's Avatar
It's not the "bulb" since you say that you can see it coming on for a second. It's very rare that the bulbs 'burn out' (even though there isn't a filament in them - just gas).
It's much more likely that the "xenon light control unit" or "Xenon headlight ignition device" is the problem.
If you are not getting any warnings from iDrive about the light control module monitoring the headlamp - it seems to me that it's the ignition device.
There are three phases to light the xenon bulb:
Starting - a pulse of 18 to 25 kVolts (208 times the voltage at the wall in the US) is generated by the ignition device
Warming - light control unit pushes to 2-3 amps into the bulb to warm it up
Running - light control unit reduces to 1-2 amps since the bulb is hot and running
It seems like your light control is not getting past the starting phase.
Swapping the bulb will indicate that it's either the ignition device or the control unit. Swap out the ignition device with the bulb too so that it can be tested.
The control unit is: 63126937223
The ignition device is: 63217162862 (D1S - I dunno what the D2S P/N is.)
Old Jun 30, 2009 | 10:30 AM
a4budak's Avatar
Not true, I had the same issue, my left side light was out and noticed that when I was in the garage it would be blink once in awhile. I though it was the module itself but took car the dealership and tech told me that since there is still very small amount of gas left in the bulb you'll see those little ignitions and they were right changing the bulb solved the problem. I do have D2S.
