what way do i turn to loosin coilover collar
My Ride: 2006 530i mystic blue
so i wanted to loosin the locking collars on my coilovers to clean and lube all the thread out and make sure everything is tight. since its 42 degrees in jersey today. i did the passanger side no problem. i used the spanners and they broke apart from one another pretty easy. lubed cleaned put tire back on. went to driver side and i cant ge the 2 collars to budge for the life of me. i used lube a hammer and flathead. all i accomplished was chewing up the teeth on the collar. am i tighting the fuckin thing the whole time. if im looking directly at the threaded body am i spinning it to the rear of the car to loosin correct? shit wont budge
well i gave up then i got borred 30 mins later and tried again after watchn a youtube vid. i was trying to loosin it the wrong freakn way. chewed the shit outta the collars but least i got it off cleaned threads good and lubed up. now i know for next time. ugg. least i lubed up all the bushings on the sway bars and stuff since i was in there so long
PelicanParts.com
07-24-2015 01:26 PM
houbmw
07-16-2015 05:48 PM
