What is this TERRIBLE engine noise?
Old 04-27-2010 | 04:13 PM
kingofire's Avatar
Originally Posted by mfrasca
For real?
I would start with a belt but it sounds like you have a dry bearing in one of the pulleys, on the front of the engine.
+1.
Old 04-27-2010 | 04:22 PM
jasperxli's Avatar
My Ride: check siggg
it should be the belts. my old car used to do that also.
Old 04-27-2010 | 04:31 PM
TexaZ3's Avatar
One of two things:
Alternator pulley bearing
One of the belt tensioners
Judging by the noise, I'd say alternator pulley.
Old 04-27-2010 | 04:37 PM
lim's Avatar
lim
My Ride: e60
+1 on the belts
get that taken care of
Old 04-27-2010 | 05:24 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
i'd change the belt, and while you're at it, spin the idler pulleys to see how they sound. usually the bearings get dry after a while.
i tried the belt dressing, and it just made the noise worse. the problem with aged belts is that the ribs get glazed/smooth and then squeek when rubbing against the pulley ribs.
Old 04-27-2010 | 05:27 PM
ivan545's Avatar
I replaced my belt due to that noise, I also lubed the bearings.
Old 04-27-2010 | 05:38 PM
pauliehcfr's Avatar
sounds like one of the tensioner pulleys has a bad bearing in it
Old 04-27-2010 | 07:47 PM
e6t's Avatar
e6t
If it's not the turbos or the supercharger, it must be a clogged fetzer valve.
Old 04-27-2010 | 07:53 PM
steeda106's Avatar
My Ride: 2004 Blacked out 530i, Carbon Fiber Pillars, Carbon Fiber Emblems (Wheels, Steering Wheel and Hood/Trunk). Blacked out kidney Grill, Smoked side marker lights, 15mm Rear Spacers, K&N Filter, Window Tint, Navigon Syst. Breyton Front Lip. Bilistein Coil Over Suspension Front & Rear Droped 1.5" Genuine M5 Pedal set. Mtechnik side skirts, RPI Exhaust.
one of your pulleys went bad, nothing major but you should have it checked out before is locks up on you.
Old 04-27-2010 | 09:25 PM
navin's Avatar
My Ride: 2005 545i
Originally Posted by tango3
LOL i dont have turbo or supercharger
@navin thanks i read the CDesign post and its exactly like what i have. Sometimes i get slight jerks when i step on the car and i also get this increased immision light randomly. The only bad thing is that i dont have warranty anymore.
Heres another useful thread on how to check the error codes and a diy to replace the leaking crank case valve.
e6tlabrat diy
Quick Reply: What is this TERRIBLE engine noise?
