What to look for?
After a couple of months of searching and trying to find the right car, I'm hoping tomorrow to go and but my e60. 2006, 56 plate (Dec 06), under 40k miles, Black with black leather, manual 520d m sport. Can anyone give me any help, questions etc and things to look for when I test drive it. When should pads/discs be changed, what is the service plan for an e60 as I've only ever owned e46 3 series coupes before.
I know I've posted a couple of topics before but I've now found (hopefully) the right one so any advice from you more experienced e60 owners would be a great help
Thanks in advance
Thanks in advance
My Ride: 525DTM
Bmw is about "inline 6" at least, I can not imagine to go and buy e60 with a 4 cylinder engine... are you 100% sure? you will sell that car after one ride in anything with ENGINE...
Hey kcbabi i'm on the verge of buying a 525d, 6 speed manual with 56,000 k on it.
I'd also love to hear any advice from the more experienced owners on what to look out for on the teat drive, ie. gear change, what upgrades if any are essential or recommended
? Thanks.......
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
Thanks in advance
Thanks in advance
This car will still be under warranty, so not too much to panic about. Just make sure it's got good tyres etc....
The i-drive will tell you the condition of the brake pads etc...go and look in the service information menu. Will also tell you when it needs servicing etc....
The E60 runs condition based servicing, which is different to the older generation cars....you bascially do individual bits, as and when required. The car lets you know.
You can extend the warranty in December if you want for further peace of mind, just make sure you tell BMW you have purchased the car if you're getting it outside of the main dealer network.
I am not real familiar with diesels (not many here stateside) but there seems to be an issue with "swirl flaps" - not sure what they are but if you use the search function at the top right you may find some helpful info on it. Other than that the iDrive will tell yo when service is required - good luck with your purchase
Originally Posted by sos' post='975518' date='Aug 13 2009, 10:53 PM
Sorted in a 2006 car
Revised design.
Anyway, i would look out for Hissing noise of the turbo, if its to loud you could have a turbo failure, (they are prone to manifold cracks) the car should ideally have a vehicle check from BMW, and you can check this via the dash as mentioned above, check the brakes and tyres, oil level and make sure you have a complete BMW service history, this is a must as the service intervals can be reset from the dash, i would pay for an AA inspection also as these cars are very sensitive to vehicle checks, look for ageing in the drivers seat, like peddle and stearing wheel to confirm mileage, the wear will be obvious as the trim is sensitive to wear! so to summarize, the biggest problems are the Turbo and manifold and swirl flaps and the rest is to be expected wear!! i hope this helps?
Steve
Originally Posted by Rislar' post='975614' date='Aug 14 2009, 12:06 AM
Sorry to piss on your bonfire but they were not removed until 07 on the LCI models, they where revised in 03 to 06 to 3mm and IMO are still weak after i removed mine!!!!
Steve
Steve
