What is this fault: Fehler: MFS fault Code: 9FEB
My Ride: 525i
I have been scouring the net with no success. Anyone know what an "MFS" is?
The fault code looks like this:
Center-Konsole
Fehler: MFS fault
Code: 9FEB
thanks!
Center-Konsole
Fehler: MFS fault
Code: 9FEB
thanks!
Looks to me like a seatbelt/restraint system fault, try looking at the SGM module in INPA and see if the error appears there.
Can you post the complete error list by any chance here?
My Ride: 525i
thanks, cmyachtie:
Here are all my faults (forgive me, Father ...)
Fault Report - BMWhat - Version: 14.60 FV
ID1: b7a61a14-bd07-405a-a6ac-203b8ac7473b-859
ID2: 1e5709f0-9428-497b-9a48-6e49780a1e5f-c72-4504
INFO: 040AD5C4B4A4978F715E4E3E33217
Base: E60 E61
Faults: 4
ECUs: 30
Filter: all
Model: 525 i M 54 25 6S 5 (85)
Battery: 13.7V
Normal communication
Normal connection
Normal Comm-Speed
B 1
Date: 2015-01-04 10:11:44
CBT.
Version: 19
Heating / AC:
Air conditioning / Klimaanlage
Fehler: Short circuit to positive or open circuit - additional water pump / Refrigerant compressors
Code: 9C77 - consider changing Aux Water Pump?
Car Communication Computer CCC
Fehler: Message failure
Code: E18F - Module noise, not an issue?
Center-Konsole
Fehler: MFS fault
Code: 9FEB - not sure what this is?
Theft alarm / Diebstahl Warnanlage
Fehler: Fault in the battery
Code: 9D12 - small battery backup for Alarm if thief cuts power, okay to leave?
Base: E60 E61
Faults: 4
ECUs: 30
Filter: all
Battery: 13.7V
Normal connection
Normal Comm-Speed
B 1
CBT.
Version: 19
Heating / AC:
Center-Konsole
Fehler: MFS fault
Am not sure if I can help you much here, Not familiar with BMBWhat tool, use INPA/DIS myself.That being said MFS is located in your centre console. Do you have stick or auto tranny? Also model year might help. Also what is car problem, in other words what is anything noticeably wrong/not functioning right?
Have you cleared the faults yet and have they come back?
Lots of times these are harmless glitches. If they don't reoccur, you'r good to go. With INPA you can tel wich fault occurs first and the subsequent faults are just the consequence of the original and not worry-some.
DetailersDomain
Detailing Forum
09-03-2015 07:08 PM
