What exactly does the CCC control?
As the title says, from my understanding the CCC are different whether you have standard or logic 7 (standard uses the amplifier from the CCC and logic 7 uses external amplifier)
Does it controls the centre heater temp, heated seat distribution, SatNav, Bluetooth + basic functions or are these external units?
I don't actually think the CCC is different for the Logic 7 and the Hi-Fi sound options. They could well be the same but in the Logic 7 its the Logic 7 amp that does all the decoding by picking up the signal on the MOST bus in the Hi-Fi sound the CCC itself does all the work. I however do know that the CCC is same between the Hi-Fi and the standard EU sound options.
The CCC is where all the processing is done i.e. the iDrive stuff and where the presets are stored. The Sat Nav is part of the CCC but the Bluetooth is another unit.
http://forums.e60.net/index.php?showtopic=...st&p=530921
Bank$hot530
07-12-2015 04:36 PM
