What exactly is a CCC?
2006 530xi
The iDrive (i.e. display/stereo/everything else) went out over a year ago. (No NAV.) At the time the dealer said I need a new CCC...$1600
I did some googling and was able to determine that CCC stands for something like Computer Control Center. But I was unable to determine what exactly is a CCC. Is it a simple module? Is it the whole CD-radio unit? Or is it contained inside the CD-radio or the iDrive display? Can someone please enlighten me? Thanks!
FWIW my local mechanic told me I just needed a new display, according to his scanner. So he showed me where to find a used one on ebay. So I purchased one and brought the car in. After 3 weeks, neither he nor his specialist outsourcers were able to install the new one and get it to work. According to him, they both managed get it to work for a period of time before it would simply stop working again (without bothering to reset my clock or tire sensors). I'm not inclined to believe him, even though he gave me a great deal (compared to stealership) with the first repair he did for me (serpentine belt and crank case gasket replaced, ~$350).
My Ride: 530i
Engine: M54
CCC is basically the whole CD player/ Nav disc reader assembly that is directly behind the two CD slots on your dash. If you were to remove that trim plate around the CD slots, you'd see a big shiny box about 6 inches wide, 5 inches tall, and 5 inches deep - that is your "CCC drive".
Thanks!
Oops. I guess I should be searching for CD/radio.
If you don't have nav, your unit is a mASK. If you have nav then your unit is a CCC. If you are going to buy another unit and you don't have nav, you might want to consider getting a CCC unit so you can upgrade it to the nav, or you could buy another unit and modify it like the 2010 cic units.
My Ride: 530i
Engine: M54
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
Not hijacking the thread but just the question.I too have MASK and thinking upgrading it to CCC or CIC. I have read several thread with DIY but still confused about the GPS antenna. Is all MASK units prewired for GPS or I need to put antenna on dashboard?
Model Year: 2005
