What else should I do?
Old 01-18-2013 | 03:29 PM
pjinca's Avatar
Originally Posted by Boost7
Sorry, I wasn't clear on my question, I wanted to know if while doing the job, could you add RTV to be preventive down the road. As I wouldn't want it to leak again in the near future just by relying on the oem gasket. I figure if the OEM gasket is prone to leaks, why could we do something to prevent it from leaking while we'll addressing the issue.
Oh, sorry for the misunderstanding. Yes, you can add a thin film of RTV for a little added security, just don't go crazy with it. We added a thin film to Toyota2BMW's bracket, not a bead a thin film.
Old 01-18-2013 | 03:44 PM
Boost7's Avatar
My Ride: E60
Model Year: 2005
OK great, the reason why I ask is because I've been trying to research more about my car which I'm still fairly new too. But not new too working on my own cars, and in the past I've rebuild my own rotary motor and gain knowledge from other engine builders to sometimes ditch the oem gasket. Just use high temp oil resistance rtv in place the gaskets. So I'm just trying to apply the same concept if possible, and ask questions first before I shoot myself in the foot.
Old 01-18-2013 | 04:01 PM
pjinca's Avatar
Questions are always good, better to ask even the most basic question than be faced with a bigger problem to fix later. I also have done at least some work to each of the cars I have owned (and quite a few that weren't mine), so yes, research and knowledge is key. LOL, this is the first car I didn't go out and immediately buy the Haynes or Chilton's manual for, there is so much info online there is no need when Google replaces even the best manuals.
(This forum helps a TON too, with guys like Joe [Rizbel] and others that do great DIYs)
Old 01-18-2013 | 04:13 PM
Stephen Max's Avatar
My Ride: 2004 545i Sport 1998 M3
Stephen, did you do the work on your own car, or a shop? Reason why I'm asking, is I'm curious about the alternator bracket seal. Is it just a gasket or some kind of o-ring? Would it be ok to add oil resistance high temp RTV to help seal it up.
I did my own work. The seal is not an o-ring, but it is not thin like a traditional gasket, and is made of a soft, rubber-like material. It fits into a groove in the alternator bracket and seals against a flat surface on the block.
Old 01-18-2013 | 10:34 PM
Boost7's Avatar
My Ride: E60
Model Year: 2005
Is this the right part? 2004-2005 BMW 545i Alternator Seal - Engine Electrical - Genuine 04-05 545i Alternator Seal - 17802-01131721 - PartsGeek
Looks like the same form and material from my old Honda valve cover gasket.
Old 01-19-2013 | 03:38 AM
Margal's Avatar
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
This is parts number of the seal 12317507806, but it is discontinued as I see from ECS tuning. But they have alternative seal, your seams OEM one.
Old 01-19-2013 | 03:49 AM
Margal's Avatar
Model Year: 2005
7. Johnson rods
8. Frammis plate
9. Muffler bearings
10. Blinker fluid
I googled Johnson rods see what they are but still can't figure out what exactly are they and what they have to do with oil leak?
Frammis plate looks like related to automatic transmission?
I have my OEM muffler changed to RPI do I still have replace the muffler bearings and where exactly are the located?
What is the blinker fluid and also where is it located?
Forgive me for all this questions but I am trying to Learn more every time.
Old 01-20-2013 | 11:28 AM
MP1472's Avatar
Originally Posted by Margal
7. Johnson rods
8. Frammis plate
9. Muffler bearings
10. Blinker fluid
Old 01-20-2013 | 11:40 AM
Margal's Avatar
Model Year: 2005
Originally Posted by MP1472
Why you just not explain it in simple words rather than whistling if you know it?
Old 01-20-2013 | 03:58 PM
Boost7's Avatar
My Ride: E60
Model Year: 2005
7. Johnson rods
8. Frammis plate
9. Muffler bearings
10. Blinker fluid
Most of those things are garage jokes - no such item.
