The wrapped wires (yellow, red)going towards the fuses/battery then towards the front.The box sits inside the black foam under the spare tire!!!!!! It is a very odd location and want to know what this electical box is, with a part number and description. Unfortunately do not have any pictures. It got wet during cleaning the trunk and my Idrive is dead! :'( Need help! :wacko:
I would just take it into the dealer service and tell them the iDrives dead. Make it look like its all dry around it - no dried water marks etc, and see what they say. Have you tried removing and reinserting all the connectors?
[snapback]138957[/snapback] I did but it is clearly full of water hence dead!!!!!!! What is this WHITE BOX? What does it do? |
http://www.realoem.com/bmw/select.do
Have a look - put in your car, and then it will come up with different selections, eg. Nav, seats etc. Try a few - it shows where the components of each system are in the car. Hope this helps - good luck! |
If I remember correctly, it was something for the headphones???
I know I read it on one of the Tech. Documents. DZ |
Its the I-Drive computer for some reason it was placed next to the spare tire.. make sure you dry everything around it otherwise you going to have to pay $1500 for it.. tell them you don't know how the water got there..blaim it on the rain.. there are two boxes there one is for the I-Drive for sure second which is underneat the tire i am not sure what its for probably for the idrive too more functions.
Good Luck |
Good Luck [snapback]139060[/snapback] |
Originally Posted by Vaqua' date='Jun 13 2005, 05:41 PM
[quote name='TurboDman' date='Jun 13 2005, 08:28 AM']Its the I-Drive computer for some reason it was placed next to the spare tire.. make sure you dry everything around it otherwise you going to have to pay $1500 for it.. tell them you don't know how the water got there..blaim it on the rain.. there are two boxes there one is for the I-Drive for sure second which is underneat the tire i am not sure what its for probably for the idrive too more functions.
Good Luck [snapback]139060[/snapback] [snapback]139126[/snapback] [/quote]I wouldn't have the balls to do it, but: Gleaning from other issues....tell them that your trunk has been popping open by itself as described in this forum, and it recently opened during a rainstorm. |
