What does a BMW software update actually do?
I've done a lot of reading on this. I have a 2004 545i and I understand that MP3 playback and bluetooth are present in the car, it's just a matter of getting them enabled.
I've called a few indi shops and one of them can do the full software update (80 modules) for $250. I believe he said it's the latest one that came out for the E60. Can someone comment what's actually updated? Will it automatically add MP3 CD playback and enable bluetooth? Will there be any other noticeable improvements?
Called the dealership and they said that per the records the car never had any software updates since it left the lot as a new car.
My Ride: 07 550i Sports Package
While I cannot comment for your car specifically, the software updates are intended to make the car more efficient. For example a DME update could affect the way the fuel injectors work,etc. A software update may also add additional features to your car if your car can handle it (hardware). You mentioned the MP3 player, while the software update can enable it, it might still not work for your car because you may not have the hardware. The mp3 only works for models that are after a certain production date. So even if you do get a software update you may still not be able to access some features because of the production year of your car. Also, not all updates are good sometimes the updates negatively affect your car. Sorry I can't answer your questions specifically but that is the jist about updates. Best to do some research on model years and production years to see what features are available.
I actually looked into coding and have found someone local, but in some cases I'm not sure if the car can even be coded to support the features with the old software.
For example, starting 04/2004 BMW started integrating bluetooth into the E60, but it wasn't enabled until 09/2004. The feature can be enabled, but I'm not sure if it can be enabled with the old software. The Service Bulletin lists that a certain version of software needs to be programmed for it to work ("CIP 13.2 or higher") That's why I was inquiring if new software is needed before I can enable the feature through coding. Is there a list which software update is needed for each feature to work, or what each software update does? I don't want the guy to start coding my car and later find out that it needs newer software...I hope that makes sense.
Also, if new software updates the I-drive, fuel economy, transmission, mp3 CD playback, bluetooth and costs $250 while just unlocking 2 features through coding costs $100, I may be better off investing the extra $150 to get the newest toys.
The deler, or anybody else, will need to hook up your car to see the latest update dates for various modules.
Your neighborhood coder would also be able to update everything the dealer can offer. It may be out of some coder's comfort zone, but the software is readily available.
I would suggest you make a list of what you woud like, then hire a coder under "no cure no pay" and get the work done. Good luck, mate.
Thanks everyone. The coder has actually done 100s of cars. I just don't want to waste his time until I figure out if I have at least V 20.0 I tried following these directions but my "hidden" screen looks totally different so I can't relate to it.
http://www.bimmerfest.com/forums/arc.../t-182514.html
Again, thanks every for your feedback.
My Ride: 2014 535 Alpine White
I found a coder in NY that enabled some feature for my car for free, it only takes like 10 min. I have features like:
Digital MPH (shows in the bottow screen of the cluster)
Window roll up and down with the key fob
Mirrors fold when door locks and opens when door is unlocked
Seat belt dong disabled
Angel eyes 100% all the time
IDrive disclaimer disable
and a few other cool things.
