What code reader
Old Jan 1, 2017 | 03:32 AM
paneuro's Avatar
My Ride: 530D Touring M Sport manual
Default What code reader
Any advice regarding code readers, what type etc. thanks Paneuro.
Old Jan 1, 2017 | 03:20 PM
JPR10's Avatar
My Ride: 2010 535i M-Sport
I think you need to be more specific. What type of codes are you trying to read? OBD Trouble / P codes? BMW specific codes?
Old Jan 1, 2017 | 08:20 PM
paneuro's Avatar
bmw 530d with dpf light on, need to know what fault codes are and try to clear them, every time i go to dealer they charge an arm and a leg to put it on their reader!
Old Jan 3, 2017 | 08:26 PM
skrelnik's Avatar
My Ride: 2010 535i xdrive
Model Year: 2010
You should see if the Carly or MHD apps are compatible with your car. Check them out on the google play store.
Old Jan 4, 2017 | 03:47 AM
paneuro's Avatar
Hi, not the answer I was looking for, I wouldn't know how to find an app nor would I know what to do with it if I found it, I was looking for somebody to say this is what you need and it will clear bmw codes. thanks Paneuro.
Old Jan 7, 2017 | 04:47 PM
Domrepkid's Avatar
My Ride: 2006 525i stick
Model Year: 525i
click link to see what it is Carly for BMW - The Most Powerful BMW App Solution
click this link to see what it does What can you do with Carly for BMW ? the BMW app from Carly? | Carly
click this link for android app https://play.google.com/store/apps/d...whatFull&hl=en
click this to buy adapter on amazon https://www.amazon.com/Original-Carl.../dp/B00X3UYXM0
it works well i have it and a mechanic friend can manipulate it just like any code reader.
Old Jan 8, 2017 | 01:51 AM
paneuro's Avatar
hi, thanks for the info re carly, i was considering buying one but it appears amazon may or may not be stocking them in future, I also emailed carly with a question and did not recieve an answer so not convinced its for me. appreciate the info though. thanks Paneuro.
Old Jan 9, 2017 | 05:53 AM
skrelnik's Avatar
Model Year: 2010
take your car to a mechanic. If you cannot figure out if Carly or MHD can work for you then you will not be able to figure out if a code reader works for you.
Old Jan 21, 2017 | 03:00 AM
paneuro's Avatar
Surely I can learn to figure these things out, I have rebuilt v12 Jaguars from the block up in the past, my only problem is a lot of the jargon that is used with code readers but I have to try. There are so many on the market to choose from, it makes it difficult.
Paneuro
Old Jan 21, 2017 | 07:22 AM
NoQuarter's Avatar
Engine: N54
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
