What is cam position sensor A, bank 2?
My Ride: 2004 545i Sport
1998 M3
Hi all,
I have tried searching but am having no luck in getting a definitive answer.
I am getting a CEL related to the cam position sensor A, bank 2. Am I correct in assuming sensor A is the sensor for the intake cam, and bank 2 is the cylinders on the passenger side of the engine?
This is for a 545i, by the way.
Thanks much.
Thanks much.
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Hi all,
Thanks much.
Thanks much.
Bank 1 is for cylinders 1-4 (passenger side)
Bank 2 is for cylinders 5-8 (driver side)
GL
My Ride: BMW 530ix
Titanium Grey
1998 M3
The sensor is about $80 from Pelican, and it is readily accessible, being on top of the valve cover. It is towards the back of the engine, so you may have to remove the plastic cowling pieces on the firewall to get at it, but that is not difficult. I can't imagine an honest mechanic charging more than an hour to do the job.
1998 M3
designation of Bank1, Bank2, exhaust, intake... same for N52 or N62.
The only difference would be the location - where those sensors are mounted on the engine.
Probation Members
My Ride: 2008 BMW 550i
I have a 550i 2008 and I’m having camshaft position sensor bank 2 sensor a and b. I’m also getting a throttle potientiometor code for range and performance could that be causing the camshalf problems for bank 2 I replaced 4 on back of motor up top and one under motor by oil pan any info will help thanks
