What airpressure in my 20"tyres?
My Ride: BMW 535D Invididual, Hartge, M-Sport
As the topic reads.
What tyrepressure should I have in mine Michelin PS II, 285x25x20 in the rear. And in front 245x30x20.
I would be very glad to hear what you run...
You should run the PSI that is designated by BMW on your door jam, regardless of tire size. Even tire manufactures recommend that, because that is the optimum load the car was designed for weight distribution. Others vary tire pressure based on personal needs, but its not the recommended set up.
My Ride: Type 523I UL (EUR)
Dev. series E60 ()
Line 5
Body type LIM
Steering LL
Door count 4
Engine N52
Cubical capacity 2.50
Power 130
Transmision HECK
Gearbox MECH
Colour TITANSILBER METALLIC (354)
Upholstery LEDER DAKOTA/SCHWARZ (LCSW)
Prod. date 2006-05-15
Order options
No. Description
1CA SELECTION COP RELEVANT VEHICLES
2NP M LT/ALY W. DOUBLE SPOKE 135 M W.RUNFLA
235 TRAILER-HITCH WITH REMOVABLE HEAD
302 ALARM SYSTEM
337 M SPORTS PACKAGE
339 SATIN CHROME
4M3 INTERIOR TRIM.FINI. ALU. CUBE PURE
428 WARNING TRIANGLE
442 CUPHOLDER
465 THROUGH-LOAD SYSTEM
470 CHILD SEAT ISOFIX ATTACHMENT
481 SPORT SEATS F DRIVER/FRONT PASSENGER
494 SEAT HEATING F DRIVER/FRONT PASSENGER
502 ; HEADLIGHT WASHER SYSTEM
508 PARK DISTANCE CONTROL (PDC)
522 XENON LIGHT
534 AUTOMATIC AIR CONDITIONING
540 CRUISE CONTROL
698 AREA-CODE 2
704 M SPORT SUSPENSION
710 M LEATHER STEERING WHEEL
715 M AERODYNAMICS PACKAGE
775 INDIVIDUAL ROOF-LINING ANTHRACITE
8SA COUNTRY SPEC. RELEASE OF NAVIGATION
8SP COP CONTROL
842 COLD CLIMATE VERSION
850 ADD FUEL TANK FILLING FOR EXPORT
863 EUROPE/DEALER DIRECTORY
877 DELETION CROSS-OVER OPERATION
885 SWEDISH/OWNERS HANDBOOK/SERVICE BOOKLET
896 DAYTIME LIGHTS FUNCTION
9AA EXTERNAL SKIN PROTECTION
Series options
No. Description
216 SERVOTRONIC
No way!! go whit the 40-45 psi or else you will distroy a new set of tires.../M
My Ride: 04 530i
06 ///M5
with 20's you really want to run higher psi (a cold 40 is typically the standard) to protect your wheels from streets that are not maintained well. When the wheels heat up from driving they will read about 46-48psi if they are 40 psi when cold.
this way the tire will take the damage and your tire stands a taller leaving less of a chance of damaging an expensive wheel. No one in there right mind is going to track a car with 20's on it if they really want all out performance anyway.
Ah, so it seems you learn something everyday...I got this from Discount Tires website, so maybe best to check your tire manufacture's website for thier load sheets to get the correct PSI recommendation.
[i]Where To Find Air Pressure Information
The correct air pressure may be found in the vehicle owner's manual or on the tire placard (attached to the vehicle door edge, doorpost, glove box door or fuel door). The placard tells you the maximum vehicle load, the cold tire pressures and the tire size recommended by the vehicle manufacturer. If you have trouble, see a local tire dealer for assistance or use our Store Locator for the nearest Discount Tire or America's Tire location.
Another valuable resource is tire load/inflation tables. Not only will this document tell you the correct tire pressure for stock sizes, but it will provide the information on optional plus sizes as well. A good example would be the findings on a Honda Civic with the stock size 185/65R-14. The recommended air pressure is 28 psi. Plus one size is 195/55R-15 with a recommended air pressure of 32 psi. Plus two size is 205/45R-16 with a recommended air pressure of 36 psi. Note how the air pressure increases with plus sizing to meet the load carrying capacity for the car.[/i]
I will not race these tyres on a track. BUT!! They will be going through som really high speeds for about 18hours ( distance 2000km one way) nonstop this summer. By high speed i mean 160-250km/h.
I will be going on a roadtrip this summer ( as always) through Europe and the speeds are high, Germany has no speed limits. In other countries either traffic is fast or I´m driving fast.
Should I have 40psi both in front and rear?
My Ride: 2006 550i, Premium Package, Navigation, Comfort Access, L7 Sound
2004 FX35, Sports Package, Stillen CAI
Some members do 40 all the way around, some do 37 front and 39 rear. I run 40 all the way around as it was advised by my mechanic.
Location: Milky Way, Earth, N. America, CA, San Jose, 95136, Latitude N 37� 16.837, Longitude W 121� 50.461
40psi on all
