What is this?!?!
Old Nov 27, 2009 | 08:13 PM
DBU's Avatar
DBU
Originally Posted by hostelo' post='1057332' date='Nov 18 2009, 03:24 AM
I am getting these error all of a sudden..............what do they mean???
I turn on the car and it goes away but after 5 min driving they come back one.
Please help because I need to know if this is serious or not.
Check the pictures below.
Thanks in advance
SZL a.k.a. Steering Angle Sensor. At least that is what they changed to fix this problem on my car.
Old Nov 27, 2009 | 09:25 PM
danzanchy's Avatar
My Ride: 545i Sport Package, Black/Grey. Got it July 09.
i used to have this problem too when my battery was goin bad... ever since i replaced it, it havent gotten the problem...
btw, do you always get the messages? cuz mine was intermittent... which could be a good indication that the battery's bad...
Originally Posted by porsche911targa' post='1063829' date='Nov 27 2009, 03:44 PM
Could be the battery. What year and what software version do you have?
a little off topic, but how do you check the software version? what's the most current?
Old Nov 28, 2009 | 03:02 AM
mikeg3tsguap's Avatar
loco thats either the steering angle sensor o si no es la bateria y el alternador el mio tambien me paso ami y varios aki
Old Nov 28, 2009 | 06:42 AM
porsche911targa's Avatar
Only the dealer can tell. Rudy probably knows what the latest rev should be.
Old Nov 29, 2009 | 12:00 PM
dawid_w's Avatar
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Do you have active steering and\or dynamic drive? Check the level of power steering fluid.
I had that problem in my 545i. It was below the limit and that triggered the errors.
Old Nov 29, 2009 | 01:37 PM
AchtungE60's Avatar
My Ride: E60 530i
Check your battery connection. Had similar issue after some work i did. My battery's ground or positive......I believe positive was tight but not tight enough. Problem came on every few days. I tightened the battery and problem went away a few mins later and never came back. Check you battery connections first. Of course if you didn't touch the battery, chances are narrow for it to loosen itself but you never know. Worth a shot.
