We'll work ahead of me I think
My Ride: 2006 BMW 550i
Well I had a 06 550i but the dealer took it back and refunded me since it had so many issues. Took the money and got a 08 535xi instead black on black not bad shape at all just wish it.had better rims and and opinions like the 550i had bit overall it's nice. Well I scanned car and got too water pump codes about volts so ordered a new one and themostste as well. Got all new hoses and new o-rngs.for.the others. New gaskets for oil pan and valve cover, spark plugs s . Putting new charge pipe on as well as new fuel cone filters for now. Also new pulleys and And belt kit I missing anything that would need replaced to fix leaks before they get.worse than already are thanks
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
How many miles are on the 535?
Take care of that transmission. Drain and fill it.
Invest in a nice transfer pump so you can easily drain and fill it often as you like.
It has a hair over 100k maybe 103 tranny feels smooth and no codes come up for not with my Carly adaptor. I am getting a code for the fuel pump and water pump and rain sensor and something ac related . Anyone has issues with he charge pipe fitting. No matter what i do it w ok my fit correctly.
My Ride: 528i
Engine: N52k
If your transmission has 100,000 miles on it, that box should have had two transmission services (one at 50,000 miles, one at 100,000 miles).
When you don't do it, this forum will come in handy when you need to rebuild the valve body and replace the solenoids.
Ill keep an eye on it for sure but knock on wood so far so good 👍. Thanks for the heads up with the info with help I'm sure I'll be on here asking away in the next few weeks when I start to out everything I got on it once weather warms a bit more .
GoRavens
02-12-2010 04:08 AM
