Well I 'F' uped
Wire feeder welder - I presume its MIG welding (using CO2). It can look pretty if its welded correctly. Make sure you prepare a bit before welding. Grind the edge so you can have the welding bead right into it. You may add small bar or strip to add strength. Check with him if he can do a 'TIG' welding which will look much better more cleaner and less impurities. Make sure he connects the earth (-ve) as close as to the welding area.
Good luck
Good luck
It looks like you may be able to take the car camping after all.
BTW, I may need the use of some of your nifty tools. What time are you leaving for the camp ground?
Yeah, maybe, still debating if it would be more fun to take the small car. I'll have to see what the route looks like. Call or text me Jason so I can get you what you need.
