Weird radiator/coolant leak
Old 12-17-2012, 01:35 PM
BimmerFan52's Avatar
Originally Posted by rockabilly_Drummer
the coolant res. it on the passenger side, this leak is appearing on the drivers side under the auto. trans. cooler area.. i cant identify where the leak is originating from as all hoses etc appear to be dry. thanks for the input tho.
Pull off the fan shroud and examine the vent tube (runs from the top of the radiator on the driver's side, across the top of the radiator, then over to the expansion tank). You'll need to do this after you have run the car and it is hot (don't disconnect any hoses while the engine is hot just remove the shroud). The vent tube can develop tiny cracks or pin holes that may not be visible when the system is cool. You will want to see it dripping.
Depending upon where the vent tube leaks, the coolant can run down the fan housing or radiator on the drivers side, appearing as if coming out of thin air. Repair ($5) or replace ($40).
Old 12-17-2012, 03:10 PM
pcy
pcy's Avatar
^ +1.
That's what I was trying to suggest...
Old 12-20-2012, 05:05 AM
rockabilly_Drummer's Avatar
ok, great, thank you i will check that out and let y'all know.. many thanks all...
Old 05-05-2015, 09:43 AM
ok, found it it was the 3part hose on the drivers side that goes to the oil cooler... so in all I have replaced the thermostat, the expansion tank and the expansion tank hose (as mentioned above) no leaks now but was getting the P0597 code (which is why I replaced the thermostat) now i am still getting the P0597 code.. any ideas?
Old 05-05-2015, 10:59 AM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
What manufacturer thermostat did you install?
Old 05-06-2015, 11:47 AM
You are probably seeing the CEL shortly after start up.
The thermostat itself has a heating coil that allows the ECU to accelerate the heating of the wax to open the thermostat quicker. If the coil is burned out or the wire harness is damaged when the ECU tests the circuit on start up it will see an open circuit and throw the code.
Pull off the harness from the thermostat and measure the resistance between the two electrical conductors on the thermostat. Should be around 16 Ohms. If it measures 1 Ohm or infinity then the coil has burned open. If it is good then start troubleshooting the wiring harness to see if you can spot any break in it.
When my alternator failed I felt it was time to change the water pump and thermostat along with other coolant system components as PM (lots of the same stuff needs to be removed to do the alternator or water pump). I tried to cheap out and bought a Beck Arnley thermostat and water pump. The electrical connectors on the thermostat were significantly undersized from the OE thermostat and I had to put a slight twist in them to get a solid connection with the wiring harness. The thermostat (made in India) lasted one week before the heater coil burned out. The water pump (made in China) lasted exactly two years before massive bearing failure.
Do yourself a favor and buy quality parts. You are saving enough already on labor.
Old 05-06-2015, 07:36 PM
UltimatePeter's Avatar
My Ride: 2006 530xi on Black 20's
Similar problems here as some previous posts... except my leak mainly drips from the passenger side of the bottom plate. Had a shop hook up pressure and none of the hoses were leaking, so it seems to be the radiator.
I have a BEHR radiator on the way from amazon for $177.
I will be attempting the radiator switch this weekend, as I have found these guides most useful:
- DIY E60 Radiator Replacement
- BMW E60 5-Series Radiator Replacement (2003-2010) - Pelican Parts Technical Article
As the Pelican article tells you in the parts section, there are apparently two radiators for automatics. Mine is the one with the extra hose for the transmission. I had to look at my current radiator to figure it out.
I'm thinking about making a youtube vid of my endeavor... We will see.
Old 07-31-2015, 01:12 PM
Here's the final product. Worked great! I saved $800.
PakiBeamer
12-09-2016 04:40 AM
abrookey
E60 M5 Discussion
09-22-2015 05:05 PM
subieworx
09-21-2015 01:19 PM
E60king
09-13-2015 05:25 AM
ST JAMES
09-04-2015 04:54 PM
Quick Reply: Weird radiator/coolant leak
