the way E60 was meant to be
Old 10-25-2014, 09:02 AM
  #631
sparky's Avatar
My Ride: E60
Just finished on my 2004 pre LCi model 530i 6 speed manual. I used oem parts such as the sport switch and tray. I didn't notice any steering wheel affect, heavier or anything else (probably because i am lacking a servotronic) but the throttle response is noticeable more responsive than before like installing a sprint booster!!! Connections are the same as in first page mentioned for pre LCI cars. I have M5 cluster instruments so no "SPORT" indication there just the light of the switch goes on when you press the switch.
Old 12-05-2014, 08:09 PM
  #632
KOC
KOC's Avatar
My Ride: E60
Model Year: 2016
I also have M5 cluster...."Sport" is there....and special light effect
Old 12-06-2014, 06:00 AM
  #633
jarvola's Avatar
My Ride: E60 520i
Just did this to my 2003 E60 520i and the steering hasn´t changed but the throttle response is a lot crisper, however , the revs take a lot longer to drop. Downshifts are ok but upshifts are jerky. This only happens when I activate the Sport mode otherwise I´d be under the bonnet looking for vacuum leaks. Anybody got any ideas??
Old 12-06-2014, 12:33 PM
  #634
seven11's Avatar
My Ride: 535
i have an LCI with sport trans, i have the sport button already,
is this the same thing?
Old 12-06-2014, 03:15 PM
  #635
tpaxadpom's Avatar
My Ride: E60 550i
Model Year: 2010
Yes.
Old 12-06-2014, 06:14 PM
  #636
FunTT535i's Avatar
My Ride: 535i navi, pdc
Engine: N54,m50
Default Please help
So I followed the steps and instead of seeing just one plug that I have to unplug and connect the cord too, I see these 3 on the bottom and one on top and don't know which to plug the switch into? Anyone that has had this please help!
2008 535i
US car
Thanks!
Edit: figured it out.
Old 12-09-2014, 03:36 PM
  #637
550iwa's Avatar
My Ride: 2007 BMW 550i
After reading all the reviews, i've decided to perform this mod. I watched roskinc's vid on how to install and used 22 gauge wire, female crimp-on tabs, heat shrink tube, and a momentary push button that i bought at radio shack. very simple install
Overall I'm happy with this mod, seems bizarre to me that it's a hidden feature, anyway when sport mode engaged i noticed fairly dramatic improvements in throttle response(no need to buy a sprint booster anymore), steering stiffness, and gear ratio as stated by previous enthusiasts.
THANKS to OP for making this happen!
-07 pre-lci 550i
Old 12-09-2014, 09:43 PM
  #638
Ashmannz's Avatar
My Ride: 05 - 525i (now with sport)
I can vouch for the install on pins 8 and 10. Worked exactly as the youtube install vid said. Makes a huge difference to a number of aspects. Very easy to install for anyone who has even a little bit of "un"-common sense.
So the car I brought that did not have sport mode option. Does now. Happy as. Cost? $2.00 for the switch.
Old 02-17-2015, 05:38 PM
  #639
NguyenAzn's Avatar
My Ride: 525i
nice ! weekend mod !
Old 02-17-2015, 05:45 PM
  #640
NguyenAzn's Avatar
My Ride: 525i
One more question. Socket number 8 9 or 10. Which one i can is positive and negative if you want to mod my own LED.
Thanks
Quick Reply: the way E60 was meant to be
