Water trickling noise from AC vents and water spray!!
Old 07-08-2013, 08:44 PM
Maini's Avatar
My Ride: 535
Model Year: 2010
The same happenned in my VW passat... and it was actually the valve in the A/C system... they had to replace that valve and fill the gas again. They say this happens when the valve in going bad... I dont recall what exactly was the valve but some dryer valve etc...
Old 07-09-2013, 07:19 AM
SmithsonGA's Avatar
Originally Posted by jgbmw
Where are the evaporator drains located? Are there any pics to show how to access them?
behind the catalytic converter heat shield. Long black tubes, just flip up the ends that are stuck.
Old 05-28-2015, 06:08 AM
Luxurytax's Avatar
My Ride: 08 528I Sport/Prem
I just wanted to add to the thread and say that I recently had this problem. I fixed it last night.
I placed the car on jack stands and removed the tranny cover underneath the car and located the two hoses on both sides on the tranny. Then I used a long extension to smack around the hoses to release the flap and warm water poured everywhere.
Problem solved
To anyone who finds this thread, using a car lift or lifting your car high enough for you to put your entire body under the car is a must. If not, you will suffer big time due to frustration.
I HIGHLY recommend jack stands.
LandRange
10-05-2015 08:47 AM
umichchris
09-10-2015 12:54 PM
lcc014
DIY: Do It Yourself
09-10-2015 05:57 AM
snoop
09-09-2015 08:47 AM
DetailersDomain
Detailing Forum
09-03-2015 07:08 PM
Quick Reply: Water trickling noise from AC vents and water spray!!
