Water Pump Brands
Old Jan 30, 2016 | 05:37 PM
twidge's Avatar
My Ride: 550i
Default Water Pump Brands
Hey Guys,
Looking to change my water pump, thermostat and expansion tank pretty soon, anyone have any suggestions on aftermarket brands? I don't want the OEM pump only because it uses a composite impeller that is known to break down. I've seen GRAF and Hepu and not sure which one i should get out of the 2. It's a $40 different between them.
Old Jan 30, 2016 | 06:43 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Actually there is a $11 difference between the two. GRAF 40.75 and HEPU $51.75. I did nto go with either. I bought a URO parts for $25. Has been going strong for over 2 years on an 05 530i. I can't tell you which one to get because I do not know which car you have to make sure I suggest the right thing. I can suggest if you have an 05 530i URO parts is the way I went.
Old Jan 30, 2016 | 07:53 PM
twidge's Avatar
My Ride: 550i
08 550i n62tu
Old Jan 31, 2016 | 05:05 AM
I would stick with URO Parts for yours unless you have a preference. ÜRO PARTS 11517586779 is $73.79 via Rock Auto. Hepu is $130.50, Graf 123.50 and Sareli is $126.50 (which was BMW supplier for previous models w/metal impeller) via Pelican Parts.
Old Jan 31, 2016 | 08:27 AM
ETNav382's Avatar
My Ride: 06 550i
Model Year: 06
I went with the Sareli, when I did mine.
Old Feb 1, 2016 | 10:50 AM
PelicanParts.com's Avatar
Vendor
My Ride: BMW 700 and More!
Salari is a good option HERE.
Old Feb 2, 2016 | 12:50 PM
txag_530i's Avatar
I'd stay away from Uro parts especially with a critical item like a water pump.
Old Feb 2, 2016 | 04:34 PM
I said Uro part because I I went with Salari (replaced everything you should replace when swapping out the pump) and it left me stranded within a year. So I figured whats the point bought a Uro part and it has lasted longer. Obviously its preference with any maintenance part but there was a reason why I suggested what I suggested.
Old Feb 2, 2016 | 07:42 PM
twidge's Avatar
My Ride: 550i
i've had issues with uro parts in the past. never again
DB_Gutz
Aug 31, 2023 09:47 AM
darnell moore
Jan 30, 2016 03:32 PM
Bill109
Jan 26, 2016 05:18 PM
Mandorake
Jan 14, 2016 07:23 PM
fishstixxx
Jan 13, 2016 08:44 AM
