Water leaking into car
My Ride: 2011 550i M sport
Hello all. Once again, I find myself in need of the great info offered here. I turn this morning to look out my rear window and what do i see ...much to my dismay I have water stains on my headliner on both sides by the c pillars. I know this was discussed before by other members and there was mention of some sort of drain clog. Yes, I did do the search but was unable to find anything. I would really appreciate your help, either by posting a link to the others topics or by offering some advice. Also, the car is out of orig warranty but is CPO...is this covered under the cpo, ie to get a new roofliner? If not, how do we clean the liner without making the stains worse(it its beige) .
Thanks in advance
Thanks in advance
My Ride: 2011 M3 Convertible, Alpine White/black, 6 speed
2011 535xi Tasmin Green, Venetian Beige
I had a similar problem during the CPO warranty period on my M3 with a foot of water in one of my rear seat foot wells and it wasn't covered at all
Problem was a clogged drain.
sounds like the sunroof drains are clogged. open the sunroof and at the front corners of the sunroof on the body you should see 2 holes-1 on each side. pour a little water near each hole and note whether it backs up or drains out behind each front tire. if it is clogged try taking a little mechanics wire to snake it out. do not use compressed air as you can blow the drain hoses off their fittings.
thanks for the quick reply. I just checked and they are both open. Anyone with any others suggestions?
I assume when you say they are both open that water is draining out? Has the rear windshield been replaced? could be an improper seal at the rear windshield. Also could be the sunroof seal. I have seen them start leaking after they have deteriorated. May also just need a sunroof adjustement. Does the sunroof glass sit fairly flush with the roofline?
well you need to air blow the drain plug under the headliner of rear seat to see if it flows fine... and cut the flap on the rear of it... bmw dealer can do that...
did you tilt your sunroof when it was raining? this can cause the problem as well..
also it might be a good idea to change the rubber seal around the sunroof because that might be worn or going bad which can cause water leak...
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
Also it could be the seal it self on the sun roof... They tend to be problematic on the wagons...
So if the seal is bad and the drains are clogged your electronics int he rear of the car could be in for some trouble.
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
My Ride: 2007 550I Sport, Jet Black w/Tan Interior: Comfort Access, Premium Package, Nav, Sirius Radio, Cold Weather Package
