Water build up
Hi,
Just something I noticed while removing the plastic housing underneath the o/s pollen filter.
There is a void underneath the brake servo with drain holes to prevent water building up. The drain holes had become blocked with leaves and there was a good 2 litres of water in there. I unblocked the holes with a few cable ties and the water drained away. I didn't check the other side of the car where there seems to be lots of expensive looking electronic control units
. There must be other people out there with the same issue.
Thanks
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
Thanks
Hi,
Thanks
Thanks
THX for the heads-up!
The drain hole for the plastic tray, underneath the pollen filter was also completely blocked with organic matter. It's located on the outer edge of the tray exiting into the wheel arch area.
Just had a flooded interior passenger compartment as a result of what you just explained... almost $7,000 in damage (thankfully USAA insurance is awesome!) The only way to access the drains completely is through the wheel well... if it backs up it will eventually empty into the passenger side of the car and there is at least 2 modules in the ebox above the drains on the passenger side under the cabin filter and one major module in the passenger floor which controls active steering, transmission etc...
Here is My link...
Clear them and all the other storm drains... I have my car back now but it took almost a month at BMW and a lot of hassle to get it all right!
Here is My link...
Here is My link...
Here is My link...
The windscreen picks up the leaves and is washed down into these areas by the rain. Mine were completely blocked. Best check the other side!!
My Ride: 535d -08 lots of goodies
120dA -06
This is a fairly common issue so a check once and a while is not out of order, im guessing that those who have their cars parked outside should check it a bit more often.
Vman33
03-14-2022 04:43 AM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
