Washers Don't Work
Old 09-07-2009 | 04:50 AM
525dMSport's Avatar
Hi, just bought my first Bimmer - a 2005 525D - since my 320. Couldn't afford a 530d yet, but really impressed with this one so far.
When I picked it up, the jets worked fine, but now just a dribble. Have topped it up with fluid, but nothing!!
Does anybody have any ideas of where to stat looking?
TIA
Mark
Old 09-07-2009 | 05:30 AM
BLooD's Avatar
TIA
Mark
any puddles on the floor when you try to use them?, sounds like the pump has died if not
Old 09-07-2009 | 09:18 AM
Kev525's Avatar
My Ride: 525i SE Black Saphire, Black Dakota Leather, 116 type alloys
TIA
Mark
I've had a similar problem in the past on my E39. There's a filter in the washer bottle to stop crud getting into the motor and which can get blocked. I think access to the washer bottle is from under the wheelarch which will be a pain to get at. If you can check that the filter is clear, then you will be able to tell if it's the motor or not that is the problem.
Old 09-07-2009 | 09:47 AM
JOHN's Avatar
My Ride: 04 525i sport, premium, winter, xenon. xm satellite radio, navwithtv dvd system, 1 jl 10w7 sub powered by xtant 1001x amp. 20x8.5/10 on nitto nt555 rubber. acs roof and decklid spoiler, breyton front spoiler.
Try Cialis
Old 09-07-2009 | 03:00 PM
Ian's Avatar
Ian
My Ride: 530D SE
I had the same problem twice! I disconnected the water hose that runs alongside the top of the engine and then using a foot pump blew air down into the water bottle and pump. Problem solved!
Old 09-07-2009 | 04:32 PM
DrLev99's Avatar
Originally Posted by JOHN' post='1000880' date='Sep 7 2009, 12:47 PM
Try Cialis
Flomax would be better.
Old 09-07-2009 | 05:22 PM
flyingpuck's Avatar
Prostate issues??
Old 09-07-2009 | 06:10 PM
luigi524td's Avatar
Clogged jets ... try a can of compressed air (the sort sold to clean up PC stuff) and use with the little stray to blow the jets clear from the topside.
Old 03-31-2010 | 07:36 AM
Mercury440's Avatar
My Ride: E60 525d
Hi,
I have a 525D and had the same problem,the cause was clogged water bottle filter.
20 minute job to fix,i followed this detail from another post
First park car with the wheels locked to left.
This is to get at the screws of the passenger side front wheel arch liner in order to access the washer tank.
Remove at least 2 screws.
Lock wheels to the right
Remove the bottom 2 outermost screws from the wheel arch liner.
I only needed to remove 4 screws in total
Carefully pull the wheel arch liner out, you should see this.
Slide the pump out. If the tank is full water will gush out when you do this.
A rubber grommet with a plastic sieve attached sits directly beneath where you removed the pump.
Remove this very carefully to avoid the sieve falling into the tank.
This grommet was covered with slimy algae. Clean it with a tooth brush ,reverse procedure for assembly
Old 03-31-2010 | 09:24 AM
545iBMW's Avatar
Check DIY section of this forum.
Nihilation
07-10-2022 12:32 PM
TexaZ3
05-06-2015 10:54 AM
sweetnlowe60
03-25-2015 08:13 PM
530e60
12-04-2007 09:08 PM
Guest_Tony
12-11-2003 02:35 AM
