Warranty Service performed on 2008 535i
My Ride: 2008 535i 6MT
~ 22,900 mi
1. AC blowing hot on drivers side, cool but not cold passenger side (Known E60 issue)
2. Long-ish crank on morning startup, no SES lamp, car runs/performs normally, sporadic OK repeated cranks throughout rest of day. (Known N54 issue)
3. Intermittant windshield wipers not fully parking issues (Known E60 issue)
Dropped car off Tuesday AM. Picked car up Friday PM. Cost $0. Had a crap-tacular 328xi coupe as a loaner.
- Replaced leaking receiver/drier and recharged system
- DME stored fault 2FBF, (long crank .. duh), LPFP test OK, 5 bar PSI output (4.75 is minimum). Reprogrammed DME. Fault resolved.
- Replaced faulty wiper relay
hope everything stays fixed...
My Ride: 535xi M3 vert
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
Long crank should have resulted in a HPFP replacement...not just a Software update.It's good they checked the LPFP, but the injectors, HPFP, and Batt voltage/ alt charge should have been looked at as well, since all could have resulted in the long crank, most likely the HPFP...
Sounds like you may be going back in the near future.
chadillac2000
42
09-13-2017 11:15 AM
S4CH
05-04-2015 09:37 AM
