Warning Light
Old Aug 30, 2010 | 08:19 PM
CameliaSha's Avatar
Hi Can any one tell me what a warning light shaped like a Radiator symbol means on a 2005 525i E60 please.
And what can I do to rectify it thanks.
Old Aug 30, 2010 | 08:20 PM
skeeter's Avatar
My Ride: '10 Switzer "Ultimate Street Edition" GT-R
Any pics of it?
Old Aug 30, 2010 | 08:45 PM
CameliaSha's Avatar
Originally Posted by skeeter
Any pics of it?
Old Aug 30, 2010 | 08:46 PM
CameliaSha's Avatar
Here is the picture,hope it is clear enough.
Old Aug 30, 2010 | 09:59 PM
sactown545's Avatar
My Ride: 2005 545i
Service engine soon light
Old Aug 31, 2010 | 04:49 AM
SilberGrauE60's Avatar
did you try re-setting the fuel filler cap?
Old Aug 31, 2010 | 03:23 PM
CameliaSha's Avatar
Can you advise how to reset the fuel filler cap?
Thanks
Old Aug 31, 2010 | 03:30 PM
mercutio's Avatar
My Ride: '06 530i M Sport N52
isn't that a general engine management fault light?
Old Aug 31, 2010 | 04:14 PM
this warning may come on if the fuel filler cap is not seated properly, so remove the cap and replace it making sure you get a good seal and you hear the second click. If this does not fix the light, inspect the rubber seal on the cap (maybe it is damaged?) and replace if damaged
This is not the only thing that may set off the SES light, but it is most likely something in the emissions control system, including the fuel vapor containment, which means the filler cap.
One last thing. You should not continue to add fuel after the pump has a normal shutoff. We sometimes call this "topping off". This can introduce fuel into the filler neck, and cause it to enter the fuel vapor containment apparatus, also triggering the warning.
Old Aug 31, 2010 | 07:17 PM
sactown545's Avatar
My Ride: 2005 545i
When my gas cap isn't on right I get a message that says check gas cap just FYI
