Viva, E60.net
Old 06-23-2009 | 06:14 AM
sixcard's Avatar
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
We had two instances of coolant loss two days apart. Had to tow in because of overheat warning.
The first case was solved (???) by replacing cooling coil for hydraulic steering and then they found the expansion tank leaking.
All this having been done, the same symptoms happened again, two days later. We are still waiting for more word from SA. He did phone to report a part on order.
Before I wrote this post I searched for ?coolant? and found many threads and posts that were helpful. Particularly helpful was luigi524, the member with that offensive ?HONK!? avatar! Thanks, my friend.
I noted all this to point out a most valuable feature of the E60.net ? the search function and the experience of the thousands of members.
We also appreciate the help of BMW assist. Mrs. sixcard was drivng on both occasions and they promtly took care of everything (except her first Tanq Tini of the day)
sixcard
Old 06-23-2009 | 06:58 AM
Krozi's Avatar
Search FTW!!
Gene will be showing up shortly to congratulate you with a medal
Old 06-23-2009 | 07:03 AM
pjinca's Avatar
Originally Posted by Krozi' post='920913' date='Jun 23 2009, 06:58 AM
Search FTW!!
Yes, he will, I think we have all managed to find useful information here - this is a great resource for info about our cars. Yes, Gene and Nerweezy are particularly good sources of info.
Old 06-23-2009 | 08:15 AM
sdg1871's Avatar
My Ride: See my signature
GL with solving the problem. You're right on the money about E60.net being a great source of information.
Old 06-23-2009 | 12:54 PM
CWS530's Avatar
Old 06-24-2009 | 01:20 PM
sixcard's Avatar
Picked up the E60 this afternoon.
They found that the electric fan had been cutting off intermittently. This caused the overheat and loss off coolant.
The fan and the sensor were replaced. The could not say, for sure, that the sensor was fault cause of the fan cut off
They also kept it overnight drove it 20 miles of so.
sixcard
Steve Gill
E60 M5 Discussion
03-20-2015 04:54 AM
CustomAngelEyes
Group Buys
321
08-22-2006 10:29 AM
das
Site Comments & Suggestions
41
08-01-2006 06:44 AM
woody
06-22-2006 08:53 PM
fpinto
Lounge
10
07-03-2004 07:24 AM
