Vibration When Going 60+ mph
Old Apr 9, 2010 | 03:20 PM
JBU2010's Avatar
My Ride: 2006 530i
I have noticed that my 530i's steering wheel starts vibrating when the vehicle reaches any speed that is over 60 mph. I have tried various roads and anything over that speed results in vibration in the steering wheel.
Any ideas on what might be causing the issue or a possible fix?
Old Apr 9, 2010 | 03:25 PM
Silver_545i's Avatar
My Ride: 2005 545i | Titanium Silver | Sport, Premium, Cold Weather, Navigation packages | Style 124 staggered rims | iPod integration | Tinted windows
I would start with the basics before digging any further. When was the last time you had your wheels balanced? Also, have you recently checked the tire pressure recently?
Old Apr 9, 2010 | 03:29 PM
Nolan222's Avatar
^ + 1
I had a similar problem just this week and I took my tires to get
balanced, they were of on 3 of the 4 wheels. Problem solved.
Old Apr 10, 2010 | 01:06 AM
safetywork's Avatar
My Ride: 2008 550i Sport (6-speed)
After re-balancing the wheels/tires, then perhaps check the bushings.....
Old Apr 10, 2010 | 01:53 AM
Slu's Avatar
Slu
I have similar problem...Wheels are balanced perfectly. What bushings you mean? Thanks.
Old Apr 10, 2010 | 04:22 AM
manaiauds's Avatar
My Ride: 2005 545i Sport Package/ Step/Orient Blue/ Anthracite Interior/ Navigation/ Cold Weather Package/ Logic 7/Sirius/ Fold down Rear Seats/ Power Rear Shades/ Xenon Adaptive Headlights/ 6000k Fog lights/ LED Angel Eyes/ LED interior/Smoked LED Side Signals/ Shadow Grill/ Shadow line Trim/ Shadow Matte Black Badges
If your wheels are perfectly balanced, check your thrust arm and control arm for worn out bushings.
Old Apr 10, 2010 | 08:57 AM
Cwest's Avatar
Are they aftermarket wheels or OEM? if there after market make sure if require hub rings which can cause vibrations, i had the same problem with aftermarket if you didnt have hub rings it will vibrate at high speed.
Old Apr 11, 2010 | 12:01 AM
Slu's Avatar
Slu
The wheels are AEZ Zeus with hub rings (just bought new rings to exclude this cause). But vibration is still there...
Old Apr 11, 2010 | 12:46 AM
chhay24's Avatar
Did you do road-force balance?
Mine for exact problem. after the balance it fixes the problem.
Old Apr 11, 2010 | 08:18 AM
jgbmw's Avatar
It doesn't smooth out around 80mph? I have slight vibration between 50-65 due to bent rims.
