Vibration under acceleration
My Ride: 530D E60 LCI
I have bmw 530d 2008 lci, car when is in low rpm from 1500 to 2300 in higher gear like 4 and try to accelerate without downshift it have some vibrations, changed guibo and driveshaft from tranny to rear axle but no big difference.
This is more noticeable when there is more load to car lole in uphill or by doing moderate acceleration if downshift then in higher rpm not noticeable.
Other issue not very important when switch to Reverse kt takes 2 seconds to engage and start to go in reverse.
Shifting and other things are perfect no complain.
Its RWD if it would be xdrive then I will write in title 530xd but car is RWD so I want to see if someone had such experiences, most vibrations are up to 2500 rpm after it they go away, and vibrations are very noticeable when there is load in car for example in uphill or when car is in 4th gear and you try to slowly accelerate by not going in third gear.
Eric
Thanks for the clarification, but there's no reason to respond like that. Some people are specific and others are not, plus in the US we don't have that model so I am less familiar with the driveline configuration options. I was just asking to see if I could offer any advice. My apologies for asking.
Eric
Eric
The reason why I registered here is to be active in forum by helping other in things what I know and also getting the same and I cant get that somewhere else or in Kosovo because this forum is 5series and here I see more motivation of all participants from other posts.
Tomorrow I will clean the injector with ultra sound because I have an error code of high correction values and maybe in specific rpm injectors go bad then engine somehow shakes and feels in whole car, then if this will not fix the trouble I will see for software update of transmission and maybe changing tranny mounts and engine mounts even that with eye look they dont look bad.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
How many km do you have on the car. Engine and trans mounts should not be bad. Have you done a trans fluid change? I would also try cleaner to run through the fuel system. I have had good luck on Red Line SI-1 through engines.
Fluid was changed, tranny mounts and engine mounts based on the guys where I do car service and where I change other parts are ok.
I saw a similar problem in another forum and a guy almost had same problem as me and he fixed it just by software update of transmission and engine ECU.
I am looking forward to get a update soon for DME and Transmission too.
By the way Injectors were cleaned today with ultra sound and no more negative values on them but problem of vibration is still there.
I wish I could help. I recently had vibration in my car, but I have x drive and my issue was related to a front axle so that doesn't help you unfortunately. I know it's frustrating so hopefully others can help.
Eric
My Ride: 2010 Bmw 535i white msport
Is this issue resolved. I have a 2010 Bmw 535i with sport transmission m sport packagE, New mecantronics new fluid and reset trans memory and Gudiņo mounts are all good just like this gentlemen. Just wondering how you resolved this issue??
