Vibration at 20 mph
Old Dec 21, 2009 | 09:43 AM
mag75's Avatar
I have an unusual vibration at 20 mph....the vibration goes away around 15 mph and 30 mph...very odd.
I have re-balanced my tires, checked my rotors, checked my tires etc....none of those seem to cause the problem.
Has anyone experienced this before? I had my control arms replaced about 5,000 miles ago. I wonder if it is a strut?
The vibration is coming from the front of the car.
Old Dec 21, 2009 | 04:56 PM
05545i's Avatar
My Ride: 2005 545i Sport 6MT
Bent wheel? Worn Front end parts? If your rotors are within spec, tires balanced (on a road force balancer), no broken belts in tires, then those may be the last two possible suspects. A strut would not cause a vibration at certain speeds, it would cause a hard ride and/or clunking noise.
Old Dec 21, 2009 | 06:20 PM
porsche911targa's Avatar
I agree with the bent wheel. Something similar happened to my old E36 and it all went away after I replaced all 4 wheels. G/L
Old Dec 21, 2009 | 06:29 PM
BigMike's Avatar
My Ride: E60
Switch your tire to the other side and see if the vibration follows. I agree, it's a bent wheel.
Old Dec 22, 2009 | 04:33 AM
530inOK's Avatar
My Ride: 540i
Model Year: 2017
My '06 had a noise coming from the front right similar to a flat spot on a tire. Slight ticking feel in the steering wheel noticable in street driving at those speeds but disappeared at highway speed. Turned out to be the right front wheel bearing. Changed at 65k miles problem solved. Good luck!
Old Dec 22, 2009 | 05:17 AM
mag75's Avatar
Thanks for all the replies.
As for the bent wheel, when they balanced the tires, would they be able to tell if the wheel was bent?
Old Dec 22, 2009 | 05:19 AM
mag75's Avatar
Thanks.....I am hoping my wheels are bent. Any idea what the cost was for the wheel bearing?
Old Dec 22, 2009 | 07:07 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
According to RealOEM the wheel hub with bearing, front, would be 282.30$. Before going to dealer because of wheel bearing, you should check it yourself to see if it's broken. That's pretty easy to do.
- Antti -
Old Dec 22, 2009 | 09:02 AM
monacobmw's Avatar
The best advisors can spot a bent wheel. Most balancers, however, are not trained, and many bent wheels do not result in a road force warning. The road force machine is told to "fix" the problem without realizing that the problem is deeper than a good fix.
It does not make sense to me that a bent wheel would produce vibration only at under 30mph. The key speed for vibration for a bent wheel (18" or 19") is around 30-35mph and 68-70mph.
Old Dec 22, 2009 | 09:13 AM
mag75's Avatar
Those were my thoughts exactly. Guess I will need to take it in regardless.
