Vibration
Hi all iv a little vibration in steering wheel at 80klm iv did balancing no joy any ideas
Vibration in the steering wheel can be caused by a number of things. The most common and easiest to fix is to determine if your rims have a hub bore of 72.5 mm. Do you have aftermarket wheels? Quick fix is to buy concentric rings.
