5Series.net - Forums
-   -   Ventilation Challanges with iDrive (https://5series.net/forums/e60-discussion-2/ventilation-challanges-idrive-5110/)
BlackBear Dec 5, 2004 10:28 PM
When I start the car and the motor is still hot the car blowes hot air into my face right at start up.
Not cool. What setting do I need to change?
BlackBear Dec 6, 2004 03:07 PM
Come on guys.. ... Someone must know?!?
speedracerF4i Dec 6, 2004 03:09 PM
Did you parked out in the sun? If so, then even $350000 Maybach will blow hot air into your face. Just keep the AC on and it will cool down.
gdavis Dec 6, 2004 05:31 PM
Not cool.? What setting do I need to change?
[snapback]65341[/snapback]
I would move to somewhere cold, like I am. Then you rarely need to worry about warm air in the vents. :lol:
(sorry, I had to add that, but I don't know where you are from your signature).
Maybe that vent adjustment would help redistribute the air some.
DXXXi Dec 6, 2004 08:22 PM
In the vent control settings in i-drive is the body of the man-figure set to blue (cool) or red (heat). I take it you are in a warm climate so you want blue.
If you have this set properly then I guess the only thing you can do until the airconditioning kicks in is turn down the fan or close the vent.
