Valve cover gaskets, Alternator bracket gasket, timing gaskets......and?
Old 07-15-2014, 02:35 PM
stylinmike's Avatar
My Ride: 2004 BMW 545i SMG
Default Valve cover gaskets, Alternator bracket gasket, timing gaskets......and?
Ordered all my parts and about to jump into a major gasket overhaul (valve cover gaskets, alternator bracket gasket, vanos o-rings, various gaskets (valvetronic, etc.). Is there any other common issues I should tackle while I have half the engine bay torn apart? Water pump maybe?
Old 07-15-2014, 03:11 PM
txag_530i's Avatar
What is the year and model of your car?
Old 07-15-2014, 03:13 PM
stylinmike's Avatar
Stupid me, typing in a hurry.
2004 545i (N62)
Old 07-15-2014, 03:20 PM
Persian_535i's Avatar
Water pump isn't a cheap part $600+ for the part alone. I'd avoid it until it actually goes out, which is usually from 60k-75k miles.
Old 07-16-2014, 07:27 AM
healthservices's Avatar
Upper timing cover gaskets, A lot of leaks stem from here and blamed on other parts
Old 07-16-2014, 08:36 AM
Jim165's Avatar
The V8 water pumps are no where near as expensive as the I6s. We have a standard mechanical pump vs. your electric one. I paid $90 for mine. I would replace it, the belts, and the spark plugs while the engine is open...
Old 07-16-2014, 07:33 PM
psam550's Avatar
My Ride: '06 550i Sport Package
Default Valve Seals
I just replaced the valve seals on my '06 550i at All German Auto (AGA) which has a tool that allows you to replace the seals without removing the thingamagig (head?). You can buy the AGA tool used on this site and Bimmerfest. AGA has posted a You Tube vid on the tool and procedure. Figured I would have it done because it's a common issue on the V8s. (Look for smoke from the exhaust at idle). And the upper timing cover and valve cover gaskets are on the way there. It's tight as a drum now. Just waiting for the coolant pipe to go. 151,000 miles and going strong!!! Love my car.
ironb
DIY: Do It Yourself
05-01-2015 05:31 AM
rlambotte
04-14-2015 06:47 AM
TexaZ3
04-08-2015 10:50 AM
thesalboy
04-08-2015 09:13 AM
biker1bmw
04-05-2015 07:44 AM
Quick Reply: Valve cover gaskets, Alternator bracket gasket, timing gaskets......and?
