5Series.net - Forums
-   -   Vacuum reservoir - broken barb fix (https://5series.net/forums/e60-discussion-2/vacuum-reservoir-broken-barb-fix-154527/)
gman6262 Nov 13, 2025 02:25 AM
I thought I would post this fix - my pressure converters went bad again after 7 years / 80,000km. When doing the diagnosis, i realized all my vacuum lines had hardened (again, after 7 years). When pulling off the old vacuum lines, I broke a barb off the vacuum reservoir. They are now over $100 to replace. So - dig into my parts bin and found a brass barb union that I tapped some threads into, drilled out the old barb and tapped mating threads into, and reassembled using some epoxy. Nice solid repair, back on the road again with full boost.
https://cimg9.ibsrv.net/gimg/5series...d37b131e6b.jpg
https://cimg0.ibsrv.net/gimg/5series...2431898cef.jpg
https://cimg1.ibsrv.net/gimg/5series...0f7dc014e5.jpg
https://cimg2.ibsrv.net/gimg/5series...8cdb059ee9.jpg
https://cimg3.ibsrv.net/gimg/5series...6bcdac65d9.jpg
I also tried upgrading the vacuum lines - got some high temperature fluorosilicone tubing and high temperature fibreglass jacket material for the replacement this time. Hoping that this tubing lasts longer than the last.
