V8 drivers: What's your temperature?
Old 04-06-2009, 08:48 AM
thedreamshop's Avatar
My Ride: 2004 545i titanium grey 6 speed manual with light grey interior. Nav, L7, cold weather, sport, sat. Modifications: suede headliner, pianno black interior trim, Ipod dock, Mtech front bumper, Angel Eyes, and flat black kidney grills.
Originally Posted by mikael' post='818196' date='Mar 16 2009, 08:37 AM
Hello all,
What temperature is your V8 (545 and 550) running at when warm? I just changed the thermostat on my 545 and now it's stable at 102-105?C when warm, is that normal? Seems pretty high to me, should I be worried?
You can check your coolant temp from the OBD by doing the following:
1) Turn ignition key to position 1 (Radio)
2) Press and hold Trip button until 01.__ appears.
3) The car?s chassis number will soon appear below this ? add the last five digits together, and remember this total for later on.
4) Press and hold Trip button to get 01.__ again, and then keep pressing the Trip button repeatedly until menu ?19 Lock On? appears
5) As soon as 00 appears below it, immediately keep pressing the Trip button until this figure reads the same as the total number of the last five digits of the chassis number which were added together previously
6) Wait momentarily until menu 01.__ appears, and then press the Trip to get menu 07.__, and the temp. will appear.
If the car is started from this menu, you will get a continuous temp. read-out until the ignition is switched off again.
The above instructions are from this post, worked like a charm.
I have the ACM installed so I am able to read temp that way, my 01/04 545i will warm up to 212 and then hold at 212 F.
Old 04-06-2009, 08:50 AM
AlexFW's Avatar
Model Year: 2005
100-105? in the city or on the highway.
Yesterday I pulled hard 10 minutes in the city and I got 125?
Old 04-06-2009, 09:37 AM
sdg1871's Avatar
My Ride: See my signature
Originally Posted by EBMCS03' post='818218' date='Mar 16 2009, 12:01 PM
Wish there was a temp gauge...
+1. It's bizzare that on a performance car such as the E60, there is no temp guage. It's such a basic guage.
At a minimum, the I Drive, which has about 10,000 functions as it is, should have the temp info. After all it has the oil level info.
Old 04-06-2009, 02:40 PM
hoodwink33's Avatar
My Ride: '04 545I SPORTS SUPENSION DINAN CAI DINAN STAGE 2 WISH LIST: RPI SCOOPS BODY KIT NEW FEET (RIMS)
Originally Posted by mikael' post='818196' date='Mar 16 2009, 11:37 AM
Hello all,
Damn feel like I'm in a math class all over again! LoL
Old 04-18-2009, 06:30 PM
blackfalcon's Avatar
My Ride: 2005 545I SMG. 2006 Nissan Titan SE. 2006 Daytona 675. YZ250F. John Deere 2520.
I used the search function to find this topic. I just replaced the thermostat on mine, because of the same increase emissions light. Before I replaced it my car was running around 83c. After I replaced i using a Whaler Thermostat it was running 100-102c for an easy 4 mile drive, and running in my garage. The dealership wanted $450 to replace the thermostat. It required about an hour of my time including fill up and drive, plus gallon of fluid and $57 part.
Old 04-18-2009, 11:47 PM
mikael's Avatar
Yes, I was also amazed by what the dealer asked to have it changed. I did it myself too and as you say it's easy.
So it seems around 105?C is normal running temp for the V8, thanks to all for posting!
Alex: 125?C sounds really high, I would have thought the cooling system was designed/dimensioned to keep the car at operating temp even while driving in the city!
Old 04-19-2009, 01:49 AM
uheenada's Avatar
My Ride: 2005 545i SMG
What I heard is that cooling components don't neccessarily kick in to stay in one temperature. Thus that's why it's called normal
temperature range not normal temperature.
Normal driving should fairly stay in one temperature or there about, however, quick spirited driving could
yield high engine temperature temporarily, but won't stay there long.
125 does sound a bit high but acceptable under lot's of stop and go traffic.
But I'm no mechanic, what do I know..
Old 04-19-2009, 02:38 AM
DD_545i's Avatar
Horrific looking procedure. I don't think I'll bother. I know if my car's running too hot then the iDrive will let me know about it with an annoying noise.
Old 04-19-2009, 03:40 AM
mikael's Avatar
Yes, it is somewhat convoluted, but very useful as a diagnostic.
It's true that the car will tell you when running too hot, but not when running too cool which was the problem I had (thermostat not closing).
Old 04-19-2009, 03:46 AM
DD_545i's Avatar
Am I wrong in thinking that if it's running too cold, then those little indicator marks on the rev counter would fail to move up to the normal range? I know when I start my car the lines come around as low as 5,000rpm but after 5 minutes or so they're up to around 6,200rpm. Maybe it would stay below 6,000rpm (even after 5-10 minutes) if it's running too cold.
Quick Reply: V8 drivers: What's your temperature?
