USB Memory Stick MP3's
Hi
Just having a problem with 1 album currently.
I put my music on a USB memory stick and plug it into the car, no problems there. However, one of the albums recently refused to play (folder and track list ok, just sits at 00:00s and then moves to the next track), the other albums on the stick are fine. So I figured the data may have got corrupted. I formatted the memory stick and put the albums back on there, same problem.
So, I bought a new memory stick, copied the albums on same problem... I've checked the albums and this particular one is 192kbs whereas the others appear to be 128kbs (haven't been through them all but the ones I was listening to are 128kbs). I've also realised that this problem actually co-incides with a recent replacement of the TCU and consequent software update (v29.2 apparently). I noted from the CD burning info on this site that the maximum bit rate is 192kbps which this album is and as I say, I've listened to it many times prior to the replacement TCU.
Any ideas why this is happening or if anyone else is having this problem? Has 192kbps support been removed?
Cheers
Barry
Cheers
Barry
My Ride: G30 M550i
Model Year: 2018
Can you try re-ripping the album from a CD? It does sound like there's some corruption of the file or something -- clearly 192kbs files should work...
My Ride: 04' 545i SMG , Oriental Blue, Congiac Leather Interior, Nav., Park Assist, Logic 7, Sports Pkg, Cross drilled slotted rotors, ceramic pads, SS Brake lines, free flow air filter and a supercharger (coming soon)etc.....all the good stuff
USB memory stick?.......This is an option on all BMW's, older vehicles with updates, and minor modifations, as well?
Originally Posted by cleung' post='631028' date='Jul 23 2008, 05:54 PM
Can I get this on my 2004 530i?
That's what I am talking about, and me on my 04' 545
I could re-rip the album, but the files play fine on my PC, from both the hard disk where I have them stored and also from the USB keys and they were working in the car via the USB key previously too.
I could also rip something else at 192kbps and see if this the reason they wont play or if something else could be causing the problem.
Sorry guys, I don't know if you can get this as a dealer retro fit? I'm sure some others on here have done it. It's sold as an iPod interface on the options list when I bought the car. The car has a USB port and a 3.5mm audio jack. You then need a special cable (not included!) to plug your iPod into the car and control it. However, you can just plug a USB memory stick (and others have tried USB hard drives with varying success) to access the mp3's directly from there.
Have a search round, I'm sure there are other posts about the retro fit possibilities.
Cheers
Barry
Cheers
Barry
I had a similar issue using an MP3 CD. The CD worked perfectly for many months thaen all of a sudden skipping, etc. Also, newly burned CD's would exhibit same issues. All of these CD's worked fine on my computer, home CD player AND the DVD navigation drive in my 550. Shutting off car and letting it sit did nothing. Finally on an inspiration I did the reboot --volume, CD eject, DVD eject and everything works fine again. The only thing that I can surmise is there is some crap left in memory. Try this and see if it works.
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather.
Mods:
Carbon filter removed.
M5 iDrive knob.
Umnitza license plate LEDs.
MP3
40% 3M tint
ACS Anti-Roll(sway) bars
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
Looks like it might be possible to retrofit however Garry at Newport BMW said they are not in the US parts system so we would have to order them from europe. I might try to pick them up in August when I go over to the UK although the exchange rate sucks.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by bardel' post='631036' date='Jul 23 2008, 06:03 PM
Hi Rudy,
Either way, try something else at 192kbps. It'll at least prove or disprove the possibility that 192kbps file compatibility was somehow removed as you speculated to earlier...
