USB jumping to FM :(
Old 11-03-2007, 12:18 PM
Russ1974's Avatar
Ever since I got the new E60, every now and then when listening to USB, it will jump to the radio. I have tried three different types / size of USB stick now and different compression settings / audio types. I've kind of just got used to it even though it is annoying, but it doesn't happen that frequently. I was in the car with my wife today and it happened, and she said "that happens in my car too" (A 5 month old E70 X5 with US. There's obviously some kind of software fault ... does anybody know of a service bulletin which reports this problem / fixes it ... ? I remember reading one about iPod jumping to FM, would that be the same issue? If so, can anybody post the link for me, I can't find it.
My car is going back in to the garage on Monday AGAIN for the squeaky brake problem which returned within a few hours of them "fixing" it last time. I'm dropping the car off Monday morning and am away until Tuesday so they are having the car for around 30 hours. Ideal time for a software upgrade, especially warranted if I can show them a service bulletin describing the fault and fix...
Thanks
Old 11-03-2007, 12:23 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
The only time mine jumps to FM is when I shut the car off while USB is active and go back to start the car when the disk isn't able to spinup on it's own. In other words, I think the car switches to FM if it can't "see" anything in the USB interface.
I don't think it should be happening on a USB stick since I assume there's much less power required to make these work. Since it's happening to you on two cars, could it be something with the way your drive(s) are formatted and/or the format and bitrate of your music?
My drive is formatted with FAT32 and my music is all 192kbps .WMA format. I never had it jump from USB to FM while listening to the drive...
Old 11-03-2007, 12:27 PM
Russ1974's Avatar
I tried different settings on my USB sticks ... currently am on 160k .MP3 but have tried others. My wife's are all in just whatever format the sound files came in, so different bitrates and different formats. All are FAT32, I don't believe any other disk type will work in the car.
You are correct, it does jump back when it can't see USB ... on my first memory stick, when it happened, I had to unplug the stick and put it back in. On the last two sticks, when it does it, I can immediately select USB again and the song even carries on playing where it left off!
Old 11-03-2007, 01:02 PM
Russ1974's Avatar
Anybody else frequently using USB and having any jumping to FM issues...? Or can anyone find that service bulletin for me, even its for iPod it might get me a software update
Old 11-03-2007, 01:32 PM
530xda's Avatar
it jumps back to radio sometimes when I get back into the car again the morning after. but no sudden jumps.
Old 11-04-2007, 08:07 AM
bernd22's Avatar
Friend of mine in Switherland that owns an LCI too has this problem also.
Old 11-04-2007, 08:59 AM
Russ1974's Avatar
Would be good if he'd sign up to the forum ... ?
Old 11-04-2007, 10:00 AM
qum_ram's Avatar
My Ride: 530i E60 Facelift
Already here ...
Did have the switch to FM after a start frequently, and very infrequent (two times) jumping to FM during the drive. So far, getting the latest software (27.2 I think, the upgrade was made for other reasons) did solve this problem. So far.
Old 11-04-2007, 10:19 AM
Russ1974's Avatar
Thanks ... still hoping for some kind of service bulletin which mentions this so I can print it and show my service dept...
Old 11-06-2007, 09:03 AM
cobradav's Avatar
Ask and you shall receive.
PLEASE NOTE: it states for E90 (3 series) and new X5, but it must be true as well for our 5/6 series. When enough of us report this as an issue that SIB will be modified to include us.
It is listed in the Adobe file I provided here, although I see I mistyped the middle number (should be 65 30 07 vice 65 33 07): http://forums.e60.net/index.php?s=&sho...st&p=483679
I will post just enough of the SIB for search engines to pick up on:
SI B65 30 07
Audio, Navigation, Monitors, Alarms, SRS October 2007
Technical Service
SUBJECT
iPod Mode is Switching to FM Mode
MODEL
E90, E91, E92, E93 *(3 Series) from 03/2007
E70 (X5) *from 04/2007
*Only with USB Audio Interface (option 6FL)
SITUATION
iPod mode switches to FM mode on its own when an iPod is connected to the USB Audio Interface via the Y-adapter cable.
The actual SIB is here:
[attachment=51668:SIB_653007.pdf]
File Type: pdf
Quick Reply: USB jumping to FM :(
