USB/iPod interface memory limitation?
Old 09-12-2007, 06:19 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
As I've posted in other threads, I've been using an "unsupported" 80GB hard drive with my USB interface. (I don't own an iPod.) Overall, it works fairly well and it's nice to be able to dump a ton of music on one device and have it all "online" in iDrive.
I'm not sure why but I'm finding that once I plug the drive in and the car takes a few minutes to index all the music (so that it can display 'albums', 'artists', 'genre', 'song', etc.) I find that some songs/albums don't show up on the lists. The only way to play these missing songs is through the 'directory' screen where it shows all the files and folders on the drive. Could there be some memory limitation that's preventing them all from being indexed?
At first, I thought there might have been some illegal character in the file or folder name since I found what appeared to be a some commonality between a few missing albums. Now, I'm ruling that theory out since there are still songs missing from the index that have nothing but regular characters in the file names.
In addition to this limitation, I still can't seem to get the .M3U playlists to work (see this thread for more information) and it's a huge bummer that whenever you return back to a listing, whether it be albums, songs, artists, etc., you always start back at the beginning of the list (alphabetically). It's even more frustrating when you finally scroll all the way down the list to the bottom (as if you wanted to listen to the band "Yes") but something causes you to take your attention away from the iDrive screen for a minute (driving the car still has a bit of a priority, right?) If you don't select a song quickly enough, the screen reverts back to the currently playing song and you have to start all over again! Usually, I'd say it's nice that you return back to the current song after a timeout period but there should be a simpler way to get back to where you were (or a simpler way to get back to the letter 'Y' if needed.)
I'm betting that this will be one of those things that BMW refines over time and, as in the past, I think it's helpful for all of us to continue to post feedback on the new stuff because as we all know, BMW engineers read this board and have listened to us from time to time.
My workaround to these problems is to organize the files on the drive in a smarter way. For example, I think I'm going to make the top-level folders reflect some alphabetical range. For example, I'm going to make folders named 'A-F', 'G-L', 'M-R', etc. and place the folders for each artist inside the appropriate folder alphabetically. It won't help me out if I want to use the 'album' list or the 'artist' list but it might make it easier for me to play some specific album from a specific artist.
I will say, in closing, that I love the USB interface and highly recommend it but as we've seen with our beloved E60's in the past, there are some minor issues that deal mainly with the user interface that can (and likely will) be improved upon...
Old 09-12-2007, 06:27 AM
pmmeke's Avatar
for all those probs and more i still think aux works best and beats usb connection any time: whats the use of seeing the song on the idrive? Just take your ipod : choose your playlist and press play. When the engine stops so does the ipod stop playing, if car hits sleep mode then the ipod stops totaly so you dont even have to put the ipod in off mode. when returning press play again and in continious the song. Easy. Sound quality is the same with aux as with usb
The lonly downside is a cable runing from the ipod to the back of the middle console at the rear of the console. Its a small 1 m cable that you can hide for the most part.
Old 09-12-2007, 06:36 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by pmmeke' post='468719' date='Sep 12 2007, 10:27 AM
for all those probs and more i still think aux works best and beats usb connection any time: whats the use of seeing the song on the idrive? Just take your ipod : choose your playlist and press play. When the engine stops so does the ipod stop playing, when returning press play again and in continious the song. Easy. Sound quality is the same with aux as with usb
Where do you keep your iPod? For me, the iDrive integration is a huge benefit. I don't want to see any wires or have to fuss around with another object like a handheld music player. My hard drive fits in the lower console compartment (where the USB jack is) and I don't have to touch it or see it. I can dial up any song I want at any time by just using the iDrive controller. (What's nice is that the car does remember the the exact place that you left off when you shut the car off so it resumes playback perfectly -- even across multiple USB drives/devices...)
Old 09-12-2007, 06:48 AM
pmmeke's Avatar
i keep it close with a bodit clip mount device.
I keep getting horror stories about the limitation of the usb interface; a lot of cool features of the ipod
dont work half of the time with ipod usb connection, long waiting times to index files, no cross fading, songs not showing up on the idrive ext... and try searching a song that has a s or t beginning the artist or song title, you have to scroll all the way up the list to get it. If you have a new ipod you can search on letter example
Yes there is that one cable but i am sure i work my ipod faster then you can work your usb connection ipod. I also keep my volume settings as the steering wheel volume buttons work also with me so
c url
http://forums.e60.net/index.php?act=attach...st&id=42951
Old 09-12-2007, 06:53 AM
Veight's Avatar
c url
For your aux input are you running your line out of the top or bottom of your Ipod? Does your car charge your Ipod somehow thru the aux input? I have the MOST bus interface cause I have the antiquated MY07 550, but it seems better to me than the aux that I have never yet used. So basically Im wondering how you power the Ipod and run "line out" not the earphone plug out from the ipod.
Old 09-12-2007, 07:16 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
c url
I understand that your setup works well for you but I don't want any additional mounts, etc. (Brodit) on the car and besides, I don't own an iPod and have no use for one outside of the car. It's much simpler for me to use USB flash drives or the HDD I'm using now. No need to charge anything, no dashboard add-ons, no wires showing, etc. Also, depending on if you're using an output from the iPod that is controlled by a volume control on the unit itself, isn't there the possibility of sound degradation if the volume on the iPod is too low or too high for the car to deal with efficiently?
Either way, if BMW would add a bit more functionality to the interface, things would be about perfect for those of us who don't own or need an iPod...
Old 09-12-2007, 09:19 AM
pmmeke's Avatar
i have connected the line out at the bottom of the ipod. It charged and connect to aux.
C my topic reply on this url
http://forums.e60.net/index.php?showtopic=...3&hl=pmmeke
ps edit: i have a extra volume amplifier built into my belkin aux charg adapter to adjust volume but ones its set no need to adjust it further if you use audio volume control feature on the ipod in settings of the ipod
Old 09-16-2007, 01:49 PM
SkyLux's Avatar
My Ride: 530D - 235hp - July 2007 6-speed Automatic transmission Exclusive Line Saphirschwarz Upholstery - Dakota Black Leather Interior trim - Anthracite Bamboo wood, high gloss Sports leather steering wheel Sunroof Hi-Fi loudspeaker system USB/Audio interface
What kind of HDD are you using ?
I tried a Western Digital Passport 60 GB HD and it didn't work.
As for songs that do not play, I converted all my MP3's to Apple format (with iTunes) and everything is OK now.
Cheers
Old 09-16-2007, 01:56 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Cheers
I'm using a Hitachi 80GB notebook drive in an external USB enclosure. It usually spins up fine but every once in a while I have to unplug it and plug it back in while tapping the case a little to get it to spin up.
As far as song playback, I have no problem at all with MP3 or WMA files. The problem isn't a playback one, it's an indexing one. It seems as if the BMW doesn't scan/index all the songs for inclusion in the "album", "genre", "artist", etc. categories...
Old 09-17-2007, 09:07 AM
freaknout's Avatar
My Ride: 545i SE - silver grey, sports suspension, 124's, nav and other stuff!
Hi Rudy
Just reading your question and the replies and noted that I have a similar problem connecting my iPod to my Playstation3.
The connection is via usb and when the iPod's first inserted it "finds" some files and not others. I would take a guess that your initial scan/indexing doesn't like certain file types. I know you said that you've looked at those but that was my solution for my iPod/PS3 drama.
regards
Jay
Quick Reply: USB/iPod interface memory limitation?
