urgent hlep
Originally Posted by Amani' post='203505' date='Nov 26 2005, 12:20 AM
well dealer fixed one but i dont like at all.....
for front its 245 / 35 /19
rear 275 / 30 /19
rear 275 / 30 /19
Stick with those if you want to be within BMW recommended specs for the speedo.
DO NOT go with 255/40/19 in front. You will rub. I've done enough research to confidently say this. I almost bought a set myself.
285/35/19 rear is ok. but they are 1.3" larger in diameter than OEM, affecting the speedo about 3mph at 65mph.
BUT if you use 285/35/19 rear and 245/35/19 front then you will run into the problem with the fronts traveling at 65mph and the rear traveling at 68mph.
[/quote]
Don't be rediculous!
Of course it will not stretch...
it will obviously get shorter
[/quote]
So bung on different diameter wheels and you get a 3-series?
thanx for very fast reply
BMW#5
i ment when u look at them u feel they r small.... maybe low profile
so u think its correct size ?
i ordered M5 rim.... the orignal M5 rim
M5 lover
the size u said it wont effect the car... i mean it wont touch the body
which rim u have and what the size
BMW#5
M5 lover
if u got the website..can u post it? thank you
[/quote]
its very easy just go to BMW dealer and ask for them
really i dont know how much i paid for them right now... but let me check
BMW#5
M5 lover
BMW#5
M5 lover
36117834625 (Front, $550 for 2)
36117834626 (Rear, $560 for 2)
Standard tyres are 255/40/19 and 285/35/19 (Continental's) - See below. Or you source non-OEM wheels of debatable quality...
BMW#5
M5 lover
BMW#5
M5 lover
I note the M5 wheels have a slightly smaller offset (than stock 19" 172's) so they 'stick out' a bit more. (Front ET12 vs ET18, Rear ET28 vs ET32) - I believe it's probably enough to avoid rubbing...
[/quote]
thanx for the info
[/quote]
loooooooool
__________________________________________________ __________
EBMCS03 u said (((((((( BUT if you use 285/35/19 rear and 245/35/19 front then you will run into the problem with the fronts traveling at 65mph and the rear traveling at 68mph))))
so that only problem i will have....... or is there any other problem ?!!!
So you're planning on going with 285/35/19 rear and 245/35/19 front?
Site Founders
Originally Posted by Amani' post='203505' date='Nov 26 2005, 02:20 AM
Hi Guys
i have 525i 2006 and i ordered M rim 19 inc. but i face one problem. what tyre size it should be for front and for rear?
rear 275 / 30 /19
both are continental
i feel they very small. so can i go for big size, and if its big ist effecting the car in long term.... and what u guys got in ur cars?
ist same ???
sorry but i need answer coz i have to take my car day after
thanx
rear 275 / 30 /19
ist same ???
thanx
All that said, yes, other sizes may fit, but why use a 285 on the rear when it was designed for the diameter and fit of a 275/30-19 (when used on a 19" wheel)?
245/35-19 and 275/30-19 is the proper tire size for a 19" wheel on all non-M E60 models. It maintains very close to the same overall diameter as stock wheels and tires, and is also the only tire size officially recommended and supported by BMW on 8.5 x 19 front and 9.5 x 19 rear on non-M E60 models. It is also the largest size officially supported by BMW.
hmmmm
every one said that i should keep the BMW recommended tire
i dont think i have other way.....
my car will be ready today with M Kit and i wish its look great
j
thanx bro for ur help and thanx to all member who give me the advice.....
when it will be ready i will post some pic
hmmmm
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
