URGENT: BMW only replacing the tensioner and not the belt
I was observing some squealing noise randomly so I went to dealership, and they are changing only the tensioner under the CPO warranty.... I read that you should always replace both the belt and the tensioner together.... Any suggestions ???
I've never heard this. Maybe if the belt is damaged. If you are concerned about it perhaps ask them to put a new belt on and then you just pay for the part. But I imagine they would not change it unless its damaged.
yeah, the belt is cheap. The labor is free while they have the belt off doing the tensioner. Your car. Don't ask them, tell them to put on a new belt at your expense.
And tell them you want the old belt. Put it in your trunk as a backup.
My Ride: 530i
Engine: M54
It's on BMWs dime, so they're going to take the cheapest route possible.
Had your car been out of CPO warranty, I can promise you they'd recommend replacing the tensioner, belts, idlers, etc.
Have them replace the belt. pay for the part.
The belt is not covered under the cpo warranty. It would be covered if you still have the maintenance plan.
My Ride: 545i sport
No need to change belt simply because idler pulley is replaced. Change belt if it shows signs of significant wear. minor cracking on ribbed side is not considered wear (IMHO).
My Ride: 2010 535xi, White/Black M Sport, Confort Access, PDC, Nav
Belt is cheap and in this case the labor is free. Should give you a lot of time before you need to worry about it again.
My Ride: 545i sport
Labor MAY be free. I have several BMW's, so I may be confusing one for the other. But, the A/C belt may have to come off to replace the main belt. So, that adds labor. But, if you only change the tensioner, you just let the belt hang there and don't have to remove the a/c belt. This will probably vary depending on engine and/or options.
Both tensioners likely use the same tool, and the mechanic already has the equipment in front of him and the tool in his hand. Literally 10 seconds to insert the tool, rotate the AC belt tensioner, lock it with a pin and then pull the AC belt off the main pulley. If a dealer tried to charge me extra labor for that I would go postal on them.
But you do bring up a good point - Knowing how deep the average $tealer attempts to reach into ones pocket, I would get an assurance up-front from the SA that I would only be charged for the belt.
