Unpredictable Steptronic behaviour
My Ride: Ordered: 530D Touring Silver Gray (A08), Auburn Dakota Leather (LCRK), Maple Wood, Steptronic, Bluetooth, 116 style 17'', Railbars, Sport suspension, Sport stering wheel
I am experiencing a strange behaviour of my automatic gearbox. So far my car (a 530D) has only 4K km but it is happened 4/5 times.
When I am in D mode suddenly I feel more vibrations from the transmission and the gearbox does not want to change gear even if I lift the gas pedal!
The last time I was on a absolutely flat motorway at 120/130 km/h speed and the gearbox was not selecting the 6th gear at all. Moreover when I needed to slightly accelerate it shifted down to 4th gear!
This lasted for 20km then everything was fine and no more vibrations!! I tried to turn off an on the engine like CTRL+ALT+DEL in Windows but it has no effect.
Has anyone experienced the same problem???
My Ride: 535 D - to be delivered end Feb 2005 - color E08 - comfort seats - executive leather balck - 122 wheels - dynamic drive - active steering - pack luxe - tecnology pack - moon roof - 6CD player - hifi system - spare wheel - BT phone
I have more or less the same symptoms (gearbow refusing to gear up) but less often: I believe that it is comming from the engine which is requesting higher revolutions in order to increase the exhaust temp. to let the particles filter burn it.
[snapback]137026[/snapback]
I assume my SW version is 16.XX since it is from Week 11.
when i put in D car change the gear same like if i put in DS mode.
They have no difference between D mode and DS mode.
Do you have this situation?? My car have no difference between D mode and DS mode...
I had mny strange things happening until BMW with ZF upgraded my gearbox software only (takes about 5 minutes) and the box settled down to a great degree.
The version of software has not yet been released in any of the CIP's from BMW and you would need to get ZF involved.
There is a difference between D and DS.
Amongst many other features you will notice that when you lift off the gas, the revs hold up higher much longer than in D where the revs drop as soon as you lift off the gas. This means that if yo hit the gas again the revs will be closer to optimum turbo range than in only D mode.
Good Luck.
Streak
My Landrover Horror Story
Good Luck.
Streak
yes streak but everything was cool until last visit dealer couse lights problem. They say that they must replaced new modull lights. And i saw that my computer in car was reprogremmedcor reseted. After that D and DS mode are same...SO i dont know what to do now...When i drive like 80 km/h in D mode and CHANGE to DS mode , there is no difference at all...
I think i must again go to dealer.Any opinions??
Originally Posted by ianni' date='Jun 7 2005, 05:42 PM
[quote name='FJPM' date='Jun 7 2005, 04:38 AM']I have more or less the same symptoms (gearbow refusing to gear up) but less often: I believe that it is comming from the engine which is requesting higher revolutions in order to increase the exhaust temp. to let the particles filter burn it.
[snapback]137144[/snapback]
[/quote]I would say that it can take 10 to 20 min in city driving
biz77
08-02-2015 04:10 PM
