Unit settings
Why is there an option to switch display pressure settings from psi to bar? I haven't come across anything that displays pressure.
Am I missing something?
My Ride: 530d SE - silver grey, black leather, auto, active xenons, active steering, bluetooth, business satnav, 6cd, poplar wood trim. chipped by West tuning - 260bhp - more torque than Ican use and still 37mpg !! fantastic!!
Previous bimmers.. 318is, 323coupe, Z3 1.9 and 2.8, E39 540 sport, E46 330ci convertible (still want an 840!!)
Originally Posted by Flowerfred' date='Oct 25 2004, 07:50 AM
Why is there an option to switch display pressure settings from psi to bar? I haven't come across anything that displayes pressure.
[snapback]49017[/snapback]
cheers
dave
Good point Fred. I have not seen any pressure based figures given through the system. I have had a flat and nothing is reported there other than "you have a flat".
Guys, Since my car is still just a thought at BMW (code 112 as of last week) I am not speaking from fact. I do have the iDrive Menu. access iMenu and go to: Display settings, then units, then preasure. Beyond that... I hope this helps or it proves those of us with a little knowledge are dangerours!
John
John
Originally Posted by gomac' date='Oct 25 2004, 09:10 AM
Guys, Since my car is still just a thought at BMW (code 112 as of last week) I am not speaking from fact. I do have the iDrive Menu. access iMenu and go to Display settings then units, the, preasure. Beyond that... I hope this helps or it proves those of us with a little knowledge are dangerours!
John![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
John
[snapback]49027[/snapback]
thanks ALOHAC. I'm finding this board invaluable in determining what to get on my new toy next!! - never had a diesel before - luvin it!
Originally Posted by Dave M' date='Oct 25 2004, 12:00 AM
[quote name='gomac' date='Oct 25 2004, 09:10 AM']Guys, Since my car is still just a thought at BMW (code 112 as of last week) I am not speaking from fact. I do have the iDrive Menu. access iMenu and go to Display settings then units, the, preasure. Beyond that... I hope this helps or it proves those of us with a little knowledge are dangerours!
John
[snapback]49037[/snapback]
[/quote]this is best of the best on the planet
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
![Wub](https://5series.net/forums/images/smilies/imported/wub.gif)
Oops sorry, I did not welcome you to the Best e60 Fourm on the Web! Nice place to hang out. (although a bit expensive with all of the neat things folks come up with and then they even give the directions.) I wonder if the next step will be the member will show up at your door to help?!
Any how a warm welcome it is through our diversity we are stronger.
Good point FF.
Hopefully it means with a new software release the I-Drive will be able to tell us which tyre is flat and by an estimated how much.
At the moment you can not see which tyre is low/flat once the warning comes on because the side walls of the run flats are so hard.
