Un-even Tyre Wear!
My Ride: 2010(60) BMW 520d SE, Manual, In Sophisto Grey with Cream/Black Interior and Piano Black trim
My e60 seems to be suffering from uneven tyre wear on the front. Both front wheels are wearing quite badly on the outside edge of the tread. The centre and inside of the tread are measuring at around 5 to 6mm, while the outsides are between 2 to 3mm.
Any advice on what I should do? Its gotta be the tracking, but will this have to be done by the dealer or can an independant tyre centre do it?
Cheers
Cheers
When they fix it, make sure it doesnt look like this.
Normally, mine get worn on the inside because of the camber.
Good luck brother.
My Ride: 2007 E60 535d M Sport
Check out this site mate:
http://www.alignmycar.co.uk/
Sounds like you need to get a 4 Wheel Alignment. My fronts were the same, but the outside shoulder on driver's side and inside shoulder on passenger side were wearing super quick. Since the alignment, it's been fine.
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
you need an alignment. BMW's normally wear faster on the inside edges due to the factory camber.
madein
06-06-2015 11:48 AM
