Umpteenth tyre puncture warning
Location: US (Bay Area/So Cal) and Europe (UK + Germany)
Check the air in the tires... The rotation speed on ONE of the tires *IS* off for this to come on.
Check the air in all the tires to be what is spec'd on your driver door badge and RESET the system. When it comes on again, you *WILL* find a tire with an air leak.
Trust me, I also doubted this twice and each time I've found a defective tire (on my Z4) or a valve problem.
One tire with a small puncture (very small). the other was a defective valve assembly.
If they are run flats, you're hosed as they cannot repair them....
Vman33
03-14-2022 04:43 AM
derooster
09-22-2015 10:10 AM
bimmerspeed
Frequently Asked Questions
09-01-2015 05:09 PM
