Tyres..!!!
I have recently moved from 275/30/19 to 275/35/19 I've left the fronts 245/35/19, the ride comofort has been improved alot but what are the downsides which i have to look out for.? (if there are any)
Thanks
Thanks
Have been running
245/35/19 on the Front
and
275/35/19 on the Rear for while now.
I have a Non-Sprot suspension and just love the ride even more now.
When I hit huge bumps the rear tire rubs on the plastic well a little sometimes otherwise no issues.
My only regret is that I should have got 235/40/19 on the front.
Would have had more wheel protection and quieter ride.
and
Have been running
and
and
I am running the M6 offset in the rear - Not very sure, is it 17mm ?
And on heavy bumps my tire does rub into the plastic cover in the wheel well.
The wheels im running on are staggered 19s, 9.5 rears and not sure of th ET and 8.5 fronts also not sure of the ET.
I know the ET is engraved on the back side of the wheels and will take them off later to check.
