I was wondering what PSI should my tyres be? After 2 months of owning the car i go to fill them up with air, and the fronts were 28PSI and the back tyres were 32psi?!?! is this normal?
I have 18 inch 245 dunlop runflats both front and back. |
There should be sticker in the driver's door jamb that will give you the correct pressure.
I looked for that however i could not find my tyre model.
FYI,
My door frame sticker says 245/40 R18 should be 32 front; 35 rear; 38 rear if M+S all seasons. |
oh... I've always put mine on 35 both front and rear... :o
Could someone also advise as to what 19" staggered setup should have? Much appreciated! |
Originally Posted by SSRL_2006
(Post 1165730)
Originally Posted by mercutio
(Post 1165792)
32 front and 38 rear :geek:
Go for the max. |
| All times are GMT -8. The time now is 06:34 AM. |
