Tyre Pressure Loss !!
My Ride: 2010 BMW 530i Alpine White Saddle Brown Interior (Gone, but not forgotten) :'(
2011 Range Rover Sport HSE Black/Tan
My car is telling me I have a Tyre pressure loss and I want to know the psi number to pump it up. It doesn't even say in the manual Does anyone know what the psi number is for my 530i so I can pump it up ?
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
really, it's not in your manual?
It's on page 188/189 via this pdf. of an 06 e60 manual:
https://5series.net/information/2006_5_...s_Manual_US.pdf
If you cant find it anywhere, you can calculate it yourselves with spreadsheet I made.
In this I use the same formula as the European car-manufacturers use so the savest known calculation at the moment.
Disclaimer: though it is the savest way to calculate, there is always a chanche of filling in the wrong data or a fault in the spreadsheet. Using the right tyre-pressure for the conditions stays your own responcibility, and I can not be held responcible for possible wrong outcome.
http://cid-a526e0eee092e6dc.skydrive.live....20tyre-pressure
in this map the spreadsheet and an example with 2 pictures of it.
If you cant work with it give me the data mentioned on the first opening sheet of the spreadsheet, and I will use it as an example here.
My Ride: 2005 BMW 545i Sport Package, Jet Black
M166 OEM Wheels
M5 Style Body kit
RPI Scoop
BMC Air Filter
Valentine One Radar Detector
35% tint all around
+1 to what people said before. also, if you have aftermarket wheels you may need a slightly different pressure. for example, if you had 17' wheels and now running on 19' then you may want to put a higher PSI.
also, slightly higher PSI can prevent bending the rims, can improve gas milage, and make tires wear not as fast
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
