typical life of an E60 water pump?
When it overheats you will know. Unfortunately, the water pump is a mechanical device and normal wear and tear takes its toll. I have changed out a couple of them on my 2000 528. There is no indication on how long one should last. One thing that will help is to add a water pump lubricant to the cooling system.
Ed
Ed
The coolant pump in my 2006 525xi just failed at 89,000 miles. Left me stranded on the highway on a very cold night waiting for a tow truck.
Repair cost at Dave Walter BMW in Akron, OH was $1,100 (Parts: $580 (rmfd pump, aluminum screws, coolant), Labor: $440, Misc/Tax: balance). Fault code stored in DME was for Electric Coolant Pump Speed Deviation.
I made it to 85k on the clock.... I have been told by a friend/BMW Tech of mine that they should last 75-100k miles... I think a lot of it has to do with the wear you put on it. Paid $160 to have it replaced but that was on the side by a BMW Tech... Its def a DIY'er though - I helped through the whole thing and have done them in other cars myself. Find a good shop or make friends with a tech outside of the shop!
And when it is failing you should get a warning on your idrive for heat and low coolant levels as they will often leak when failing.
Symptoms of the failed water pump in my case were:
1. Complete loss of cabin heat coming through the vents was the first thing I noticed
2. About 3 minutes later a yellow iDrive warning came on that stated the engine was running hot and that I should begin driving moderately to cool it
3. About 30 seconds after the first warning I got a red iDrive warning that the engine was overheated and that I should stop the car immediately
These fail a lot because they use plastic for the impellers instead of metal. Changing water pump is cheap and easy though. You can get a metal impellar water pump from ECStuning for like $55 (cheaper than our cup holders).
WHEN I CHANGED MY PUMP
Different cars, different parts, different ease of access, different repair costs.
Snap I always forget that 525s have N52 and M54... huge difference. My bad.
ECS has the thermo and waterpump decently priced- http://www.ecstuning.com/BMW-E60-525...gine/Cooling/2
There's like 10 videos on how to change the M54 pump and none on N52 (3 minute search). Time for someone to make one
