two quick questions
going on a 3500 mile trip on sunday , whats the best tyre pressure for my car , whats on the door jam or do you know better, psi please
also all four doors are creaking , just need a quick fix for 2 weeks , do i spray them with polish , wd40 or what and if so where exactly
car is going at end of august so it will do untill then.
thanks
thanks
i usually keep 30 psi all around, which i believe is recommended. but for a firmer ride and maybe better gas mileage, you can go higher (i.e. 30 front, 35 rear).
BTW, I recently did a 3500 round trip this past May. kept my tires at 30 psi and had a very comfortable ride.
My Ride: Titanium Silver 2004 525i, style 116 alloys,
Autoglym leather care cream rubbed onto the seals should keep them quiet for 1 to 3 months I've found.
(on the black strip that looks like felt)
My Ride: E60 523i
silver, black leather , sunroof , bluetooth , pdc , M sports kit , Steptronic gear box , active stearing , active cruise control
Sorry , but why would people want to seal there doors is it because it is noisy or what thanks
thanks
thanks
Pressure about + 0.5 or 50 up from the recommended minumum, if the car is heavy loaded even more.
You'll have the recommantions on the B-pillar or in the manual.
The seals will creak if you wax them or the metallic inside door frames.
Keep them as clean as possible.
