Turning signal problem... It's stuck! Help!!!
Searched around the net and I've found limited information on my problem:
My left turning signal gets stuck on. Even when I activate my right signal, it just illuminates the left. When I hold right, the right side does blink, but it doesn't cancel the left. If i turn the wheel to the left enough, it will cancel, but nothing else short of shutting down the car does. Even turning on the hazards just activates the left turning signals. High-beams work when this is happening. Eventually, after enough messing with it, the entire turning signal stalk stops working. At this point the hazards work fine, however no turning signals and no high-beams. I don't notice any other issues... If the car sits for a while, everything works as normal. Then out of the nowhere the left turn signal gets stuck and the cycle starts again. All bulbs look fine. No warning lights. There doesn't seem to be a fuse associated with the turning lights. Any ideas or anyone ever have this problem?? |
Combination switch needs to be replaced. There are instructions posted on the forum, please search.
